Inflating Balloon: Help Sergio Find the Correct Answer
  • Thread starter Thread starter S_fabris
    Balloon
To calculate the work done by the balloon on the surrounding air, only the given excess pressure of 4.2e5 Pa should be used, without adding atmospheric pressure. The change in volume is 0.00082 m³. The correct formula for work is W = P x dV, leading to W = 4.2e5 Pa x 0.00082 m³. This results in a work value of 344.4 J, which is the correct answer for the problem.
S_fabris
This is one of many postings from me this week unfortunately I'm just not getting the correct answers...anyway here I go :
A toy balloon is inflated with helium at a constant pressure that is 4.2e5 Pa in excess of atmospheric pressure. If the balloon inflates from a volume of 1.4e-4m3 to 9.6e-4m3, how much work is done by the balloon on the surrounding air? answer in J
this is my work
P= 4.2e5Pa + 101300Pa
= 521 300 Pa
dV = (Vf-Vi) = (9.6e-4 - 1.4e-4)
= 0.00082m3
W= 521 300Pa x (0.00082m3)
427.466 J (incorrect on homework server)
I'm guessing it has something to do with the work on the surrounding air...I have been looking in my books and course notes for this and I can't find anything...can anybody help me out??
Any help is appreciated,
Sergio
Is this what the problem is supposed to be: A toy balloon is inflated with helium at a constant pressure that is 4.2e^5 Pa in excess of atmospheric pressure. If the balloon inflates from a volume of 1.4e^{-4}m^3 to 9.6e^{-4}m^3, how much work is done by the balloon on the surrounding air? answer in J
Yes that's exactly the question on my homework page :)
Hey we finally got the answer...for the pressure...do not add the atmospheric pressure...simply use the one in the question
THank you for your time
Sergio
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
