teng125 said:
is it 6(1.4-t(1) )??no,still can't find it.pls tell me
thanx
Okay, take out a pen and some paper,
varies linearly means that if you plot an acceleration - time graph, you will get a
straight line (that's what linear means).
So at t = 0, yor acceleration is -40 ft / s (that means the line goes through the point (0; -40)), and at t = t(1), your acceleration is -6 ft / s (that means the line goes through the point (t(1), -6)). t(1) is some positive value, just choose it randomly.
Now just connect the 2 point (0; -40), and (t(1), -6), you'll have a line. That line shows you the acceleration on the interval [0; t(1)], right? And it's a right trapezoid.
The area of a trapezoid is:
A = \frac{1}{2} (a + b) h
The parallel sides' lengths are 40, and 6. The height is t(1). Do you see why? Just look at your graph.
But since the trapezoid is
under the x-axis, so:
\Delta v = \int \limits_{0} ^ {t(1)} a(t) dt = -A_{\mbox{trapezoid}}. Do you know why?
So you'll have:
\Delta v = \int \limits_{0} ^ {t(1)} a(t) dt = -A_{\mbox{trapezoid}} = -\frac{1}{2} (40 + 6) t(1).
Now it's almost there (I almost show you the answer
). Can you go from here? :)
If you have any problem understanding anything from my post, just shout it out. :)
