Injective and surjective functions
12 replies · 4K views
Ciaran
Hello,
I've been reading about injectivity from Z to N and surjectivity from N to Z and was wondering whether there was some kind of algorithm that could generate these specific types of functions?
Ciaran said:
Hello,
Sure.
How about $\mathbb Z \to \mathbb N$ given by $n \mapsto \begin{cases}
-2n-1 & \text{if $n < 0$} \\
2n & \text{if $n \ge 0$}
\end{cases}$
Is it injective?
How about surjective?
Hello!
Thanks for the reply- the function is injective but not surjective. What about surjective from N to Z and is there some algorithm for generating a function satisfying such conditions?
Ciaran said:
Hello!
Yes, it is injective... but isn't it also surjective? Doesn't every element in $\mathbb N$ have an original in $\mathbb Z$?
Oh I see, I was asking for 2 separate functions- I was asked by my instructor to find a solely injective function from Z to N and a solely surjective function from N to Z. I was struggling so wondered if there was some way of generating one such that I didn't just have to think of a function then see if it fits either category?
Ah. I suspect the intention is to make you familiar with what injectivity and surjectivity actually mean.
When you grasp the concept, there should be no need for any generating algorithm.
I suggest to draw what it means and then come up with a matching function.
Or otherwise try a couple of functions, see what they do, categorize them, and think up what you need to cover any missing category.
It's the conditions that are proving to be tricky to me- for the surjective function, does it mean my function can only generate integer values ?
I'm pretty sure g(x)= x! and f(x)=x^2 are injective and surjective, respectively
Not precisely.
The fact that we're limiting ourselves to functions from Z to N, respectively N to Z, implies that the function can only generate integer values.
As yet that is unrelated to whether it is surjective or not.
Sorry, but no.
For starters, I assume you are talking about functions from Z to N.
If so, then g is then undefined for negative values, meaning it is not a function from Z to N (depending on the definition of function you're using).
Another problem with g is the g(x)=1 has 2 originals, and is therefore not injective (see below).
And the problem with f is that f(x)=3 has no originals, and is therefore not surjective.
To be clear, injective means that every element in the codomain has at most 1 original.
And surjective means that every element in the codomain has at least 1 original.
Ahhh, what about f(x) = x/2 if x is even, (1-x)/2 if x is odd. And g(x)=2x+1 for positive x, -2x for negative x?
Are we talking about functions from Z to N?
Because if so, then f is not a function, since an even negative x is not mapped to N.
As for g, did you mean it to be injective or surjective?
Or put otherwise, what do you think about it being either injective or surjective?
My apologies, I have only now just noticed you replied! f(x) was meant to be surjective from N to Z and g(x) was meant to be injective from Z to N
What is N exactly? Does it include 0 or not?
Assuming that N is { 1, 2, 3, ... }, f is indeed surjective. Is f also injective?
As for g, what is the image of 0? You didn't specify.
It has consequences for whether g is injective or not.
