Inner Product Space/Hilbert Space Problem
mattos90
3. If z is any fixed element of an inner product space X, show that f(x) = <x,z> defines a bounded linear functional f on X, of norm ||z||.
4. Consider Prob. 3. If the mapping X --> X' (the space of continuous linear functionals) given by z |--> f is surjective, show that X must be a Hilbert space.
I solved question 3 without any difficulty, but I can't seem to make any progress on question 4.
To start you off, write down explicitly what it means for a map to be surjective and write down the requirements for something to be a Hilbert space.
What are your ideas about showing that the map z |--> f is surjective?
How would you show each of the requirements for a Hilbert space?
Coto
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
