Installing 2X24 Character LCD in Water-tight Box
  • Thread starter Thread starter j777
    Box Lcd
To mount a 2X24 character LCD in an IP67 enclosure, using a clear plastic lid is a common solution, but concerns about condensation arise. Companies do manufacture LCD panels with IP67-rated glass that include gaskets for sealing. However, maintaining visibility while preventing moisture buildup can be challenging in harsh environments. An example of a suitable product is a 16-bit microcontroller with a display integrated into an IP67 enclosure. Exploring specialized manufacturers may yield better options for achieving both visibility and waterproofing.
j777
Hello,
I need to mount a 2X24 character LCD inside of an IP67 enclosure. The only way I've been able to find to maintain IP67 and still be able to view the LCD is to use an enclosure with a clear plastic lid. While this is a somewhat adequate solution I wonder if there is a better way of doing this. Is there a company that makes enclosures (IP67/NEMA 4X) with an LCD window built in or some other solution to solve this problem?
Thanks
Lots of companies make LCD panels where the glass is IP67 and they seal with a gasket around the front. The problem with using a window is getting condensation inside the case under the window - if it IP67 it is likely to be used in bad conditions.
As an example we use these http://www.cantrak-int.com/ in a lot of equipement, there are an entire 16bit micro + display in a IP67 enclosure.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
