Installing/loading mathematica packages
  • Thread starter Thread starter Reedeegi
    Mathematica
To install and load Mathematica packages, first, write the package in the correct format and save it in the packages sub-directory for easy access. Alternatively, adjust the path in Mathematica using directory commands. Use the loading command, either << or "Needs," in your notebook to load the package. After loading, you can call the public functions defined in the package. Properly following these steps ensures successful package integration in Mathematica 7.
Reedeegi
How is this done? I have Mathematica 7, by the way.
Mathematics news on Phys.org
Hi. First you have to write the package in the correct form, then save it in the packages sub-directory so Mathematica can find it or maybe change the path in Mathematica with one of the directory commands. Then you need to use the command that loads the package in your notebook. That's either << or the "Needs" command. Then just call the functions that you made public in the package.
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
