Instanton configurations of an even anharmonic oscillator
  • Thread starter Thread starter Syrius
    even Oscillator
Syrius
Cheers everybody,
the Hamiltonian of an even anharmonic oscillator is defined as
H_N(g) = - \frac{1}{2} ∂_q^2 + \frac{1}{2} q^2 + g q^N (N even).
In a paper (PRl 102, 011601) I found that to determine the eigenenergies of this system the Euclidean path integral formalism is used. They concluded that they have to use instanton configurations.
Since some googling of this term gave me only explanations in terms of Yang-Mills theories or string theory stuff and nothing else, my first question is: How are these instanton configurations defined for a given Hamiltonian.
From the Hamiltonian they further conclude that instanton configurations only exist for negative g. To find then the configurations they scale q(t) = (-g)^{-1/(N-2)} ζ(t).. Maybe it will be obvious once I know the exact definition of instanton configuration, but why do they then scale q(t) with this prefactor?
Many thanks in advance for your answers!
Greetings, Syrius
An instanton, in general, is a solution that interpolates between two vacua of the theory in such a way that it becomes topologically "trapped" at infinity.
You can realize an extremely simple example using a leather belt on a table. If you lay the belt on the table, it wants to lie flat, because of gravity. This is the vacuum configuration. But there are two distinct vacua: it can lie flat on its front, or its back.
Now take the belt and put a half-twist in it, and then hold the ends of it down on the table with your hands. At either end, the belt is in one of its vacuum configurations; lying on its front on one end, and on its back on the other. But somewhere in the middle, the belt will be sticking straight up, in a configuration with positive energy. This part in the middle cannot fall down, because the ends of the belt are trapped; the belt is kept in a positive-energy configuration by topology.
This "belt trick" is actually the sine-Gordon "kink soliton", more or less. The distinction between a soliton and an instanton is mostly semantics; an instanton is topologically trapped in the past and the future, so that the lump of positive energy occurs for an "instant" and then disappears.
As for why g has to be negative in your Hamiltonian, the reason is that there must be a double-well potential of some kind. So the anharmonic term must come with the opposite sign to the harmonic term. This way you will have two vacua to interpolate between.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
26K
22K
9K
13K
