Insulation=> simple problem just confused a bit.
The discussion revolves around calculating the energy required to increase the temperature of a diatomic gas in a well-insulated house. The user seeks clarification on whether the volume remains constant during the temperature increase, as this affects the calculations. For part a, they are uncertain about the implications of insulation on temperature changes, while for part b, they inquire if they can use the potential energy formula to find the mass that can be lifted with the calculated energy. The user expresses urgency due to an upcoming quiz and requests assistance to confirm their understanding. Overall, the thread highlights confusion about thermodynamic principles in a practical context.
~christina~
A house has well insulated walls. It contains a vol of 100m^3 of air at 300K
a) calculate the E required to increase the T of the diatomic gas by 1.00C
b) If this E could be used to lift an object of mass m through a height of 2.00m what is the mass of m?
Q=m C_v \Delta T= > constant V
\Delta U= Q
C_v= 5R/2
Q=mC_p \Delta T=> constant P
\Delta U= Q + W= nC_p \Delta T + (-P\Delta V)
C_p= 7R/2
a)calculate the E required to increase the T of the diatomic gas by 1.00C
I would think that the insulation would make the volume be constant but that's what I'm not sure about. (I was thinking that the temperature would be constant but if they ask how much E is needed to raise the temperature then it can't be that the temperature would be the same...)
b) b) If this E could be used to lift an object of mass m through a height of 2.00m what is the mass of m?
would I just use \Delta PE= mghand find m ?
Help please..
Thank you very much.
can someone help me please?
I have a quiz and if no one does then I'll be forced to assume that the volume doesn't change even if it may be incorrect. :frown:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
