Partial Discharge Analysis for Transformer Insulation Testing
Partial discharge analysis is a method for testing transformer insulation, particularly between primary and secondary windings. The process involves shorting both windings, applying voltage, and taking measurements to assess insulation integrity. However, testing turn-to-turn insulation using partial discharge analysis poses challenges that require further guidance. The IEEE recommended practice for testing insulation, specifically IEE Std. 43-2000, is suggested as a valuable resource for this purpose. Understanding these testing methods is crucial for ensuring transformer reliability and safety.
EE4me
TL;DR Summary
I would like to know how to test turn to turn insulation.
I would like to test the insulation of a transformer using partial discharge analysis. Testing insulation between the primary and secondary is pretty straightforward. I short the primary as well as the secondary, apply voltage across the two, then take my measurements.
I also need to test the turn to turn insulation for the primary and the secondary using partial discharge analysis which I'm not sure how to do. Any help is appreciated.
I'm not an expert on that. But the first place I would look is this:
IEEE recommended practice for testing insulation ...
IEE Std. 43-2000
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
