Integer partitioning problem - for fun
  • Thread starter Thread starter Pepper Mint
    Fun Integer
The discussion revolves around a problem involving two integers, m and n, used to generate a list of integers based on a specific formula. The list starts at m and each subsequent integer is derived by adding n to the previous integer, continuing until M integers are generated. After creating this list, a small number of integers (N) are randomly deleted, and the challenge is to deduce the original values of m and n without retaining any memory of them. Participants highlight that while it is impossible to determine m and n definitively due to the loss of information, statistical analysis can be employed to estimate the likely values based on the differences between the remaining integers in the list. The discussion emphasizes that knowledge of N and M is crucial for any meaningful analysis, as it affects the potential combinations of m and n that could produce the observed results.
Pepper Mint
I have a user input of 2 integers (m,n)
Then my system will generate 1 list of M (m,n < M) integers that start at m and end at Mth integer of value xM. The formula to calculate xM is followed by
x_0=m
x_M=x_{M-1}+n
After the list is generated I randomly delete N (N << M) rows from it and given that my system isn't allowed to remember (m,n), how can I find out what values (m,n) were ?
For example
(m,n)=(2,5)
M=5 => L={2,7,12,17,22}
deleting L2,4 yields L={2,12,22}
In general case you can't.
I would start checking what all xi-xi-1 (actually every xi-xj) have in common.
Likes Pepper Mint
As Borek says, you can't do this if you don't know ##N## and ##M##. But you can statistically analyze what the ##n## and ##m## values likely might have been.
Likes Pepper Mint
Similar to the 2024 thread, here I start the 2025 thread. As always it is getting increasingly difficult to predict, so I will make a list based on other article predictions. You can also leave your prediction here. Here are the predictions of 2024 that did not make it: Peter Shor, David Deutsch and all the rest of the quantum computing community (various sources) Pablo Jarrillo Herrero, Allan McDonald and Rafi Bistritzer for magic angle in twisted graphene (various sources) Christoph...
Thread 'My experience as a hostage'
I believe it was the summer of 2001 that I made a trip to Peru for my work. I was a private contractor doing automation engineering and programming for various companies, including Frito Lay. Frito had purchased a snack food plant near Lima, Peru, and sent me down to oversee the upgrades to the systems and the startup. Peru was still suffering the ills of a recent civil war and I knew it was dicey, but the money was too good to pass up. It was a long trip to Lima; about 14 hours of airtime...
