Integral involving powers of trig functions
The discussion revolves around the integral ∫(sinx + sin^3x)dx/(cos2x), focusing on the methods of integration and verification of results. Participants are exploring the intricacies of trigonometric integrals and the application of the Fundamental Theorem of Calculus.
  • Participants discuss the correctness of integration methods and the possibility of simpler solutions. There are inquiries about how to verify the correctness of an antiderivative by differentiation.
Some participants have provided guidance on checking answers through differentiation, while others have pointed out potential mistakes in the integration process. Multiple interpretations of the problem and its solution methods are being explored.
There are mentions of specific mistakes in the integration steps, such as missing terms in the numerator and the complexity of the integral suggesting that a simpler method may not exist.
Memo
∫(sinx+sin^3x)dx/(cos2x)
cos2x=2cos^2x-1
Could you check if my answer is correct? Thank you very much!
Is therea simpler way to solve the math?
Memo said:
Homework Statement: ∫(sinx+sin^3x)dx/(cos2x)
Relevant Equations: cos2x=2cos^2x-1
You can do that yourself by differentiating your answer and checking you get the original integrand.
Your method looks good to me. Maybe there's a trick, but not always.
Could you tell me how?
If you integrate a function f(x) and get an antiderivative F(x) + C, you can check your answer by differentiating F(x). If your antiderivative is correct, the result will be f(x).
In symbols...
If ##\int f(x) dx = F(x) + C##, then ##\frac d{dx}\left(F(x) + C\right) = f(x)##
In symbols...
It appears that I was wrong
## \text { The method is good, but there are two mistakes. } ##
## \text { The first one is: } u ^ 2 \text { is missed } ##
## \text { in the part where } \int \frac { u ^ 2 – 2 } { ( \sqrt 2 u – 1 ) ( \sqrt 2 u + 1 ) } \, du \text { becomes } \int \frac { 1 } { \sqrt 2 u + 1} \, du - \int \frac { 1 } { \sqrt 2 u – 1 } \, du \text { . } ##
## \text { The second one is: } \sqrt 2 \text { is missed } ##
## \text { in the part where } \int \frac { 1 } { \sqrt 2 u + 1 } \, du - \int \frac { 1 } { \sqrt 2 u – 1 } \ , du \text { becomes } \ln | \sqrt 2 u + 1 | - \ln | \sqrt 2 u - 1 | \text { . } ##
## \text { ... and there is not a simpler way. } ##
In symbols...
Look up the Fundamental Theorem of Calculus.
You have correctly obtained <br /> \int \frac{\sin x + \sin^3 x}{\cos 2x}\,dx = \int \frac{u^2 - 2}{2u^2 - 1}\,du. But you then obtain the partial fraction decomposition of \frac{1}{2u^2 - 1}, which is not your integrand; the numerator is u^2 - 2 not 1. So you need a further step first: \begin{split}<br /> \int \frac{u^2 - 2}{2u^2 - 1}\,du &amp;= \frac12 \int \frac{2u^2 - 4}{2u^2 - 1}\,du \\<br /> &amp;= \frac 12 \int 1 - \frac{3}{2u^2 - 1}\,du \\<br /> &amp;= \frac u2 - \frac{3}{4} \int \frac{1}{u^2 - \frac12}\,du\end{split} and now you can use your partial fraction decomposition.
  • · Replies 17 ·
  • · Replies 18 ·
