Integral of Open Set Homework: The Attempt at a Solution
  • Thread starter Thread starter cummings12332
    Integral Set
cummings12332
for part A i assume that f is in norm space C[0,1],||.|| , then choose a sequence fn in C[o,1] s.t fn->f then for 0<fn<1 so 0<f<1 i.e. A is closed i am not sure my answer here
for part B i assume the anti-derivatice of f(t) to be K(t)+c therefore, by F(f)=2K(1/2)+1/2-K(1)-K(0) then how should i prove it is cts ?
I don't see how that proves anything. You need to prove that if f_n is a convergent sequence in A such that f_n\rightarrow f, that then f is an element of A.
OK, but that doesn't really help. What definition of continuous would you like to use here? Can you state it?
Also, it would be a great help for us if you would type your posts in LaTeX: https://www.physicsforums.com/showpost.php?p=3977517&postcount=3
δ
if f_n is a convergent sequence in A such that f_n\rightarrow f, then for f_n is in A , A is a subset of C[0,1] so fn is bounded by 0 and 1 and continuous on [0,1] so fn is uniformly continuous to f ,then f is bouded by 0,1 which is in A?
and secound part if i use the definition of continuous , then exists a δ,s.t. |f(x)-f(y)|<δ implies that |F(f(x))-F(g(x))|<esillope . and just fixed the esillope . and i can solve it out now many thanks
Sure. But can you actually prove that f is bounded by 0 and 1? Once you proven that, I agree that the above shows that A is closed.
Protip: we usually talk about epsilon instead of esillope
OK, so you you need to make |F(f)-F(g)| small somehow by making \|f-g\|_\infty small. So, let us start by writing
|F(f)-F(g)|=\left|\int_0^{1/2}f(t)dt + \int_{1/2}^1 (1-f(t))dt - \int_0^{1/2} g(t)dt - \int_{1/2}^1 (1-g(t))dt\right|
Try to find a good estimation for that.
i not sure how to prove that 0<f<1 ,which way should i begin with??
You should not prove 0<f<1, you should prove 0\leq f\leq 1.
Start by fixing an x\in [0,1]. Then try to deduce from f_n(x)\rightarrow f(x) that 0\leq f(x)\leq 1.
for me ,it is obviouse. 0\leq f_n\leq 1. then max fn =1, min fn =0 and limfn =f so by sanwich rule 0\leq f(x)\leq 1 i just don't know how should i prove that f is bounded by [0,1] here
Why should \max f_n=1 and \min f_n=0?? That's really weird.
For example, take the map
f_n:[0,1]\rightarrow \mathbb{R}:x\rightarrow x\rightarrow \frac{1}{n}
then the \max f_n=\min f_n=\frac{1}{n}.
You're really making it harder than it is. I'm just asking you that if (y_n)_n is a convergent sequence with y_n\rightarrow y, and if 0\leq y_n\leq 1, then 0\leq y\leq 1. It doesn't even have anything to do with functions.
omg! that's what i thought at the beginning! many thanks !
