Integral over a set of measure 0
The integral over a set of measure zero is generally considered to be zero for ordinary functions, according to Lebesgue integration principles. If a function takes on infinite values on a measure zero set, the convention that infinity times zero equals zero is often adopted to maintain consistency. Riemann integration does not apply to functions that are extended-real-number-valued, which complicates the discussion of such cases. The monotone convergence theorem supports that if a sequence of functions approximates a function from below, the integral remains zero. Overall, defining infinity times zero as zero helps avoid inconsistencies in integration results.
Boot20
Is the integral over a set of measure zero always equals to zero? Can the integral be undefined?
It may be undefined if the function itself is peculiar with infinity as its value. For ordinary functions the integral will be 0.
Sorry, I have the question that, if Lebesgue integration, they always define the convention \infty \cdot 0 = 0, so, in this case, even the function takes \infty in a set of measure 0, the integral is still 0?
Convention is an easy way out.
For Lebesgue integration, that the integral over a set of measure zero is a rather trivial theorem, following from the fact that all simple functions have integral zero -- so via (what I believe is) the usual formulation, it doesn't even need to be treated as a special case.
Riemann integration assumes the function is real-valued, so it doesn't even apply if you are considering extended-real-number-valued functions that take on the values +\infty or -\infty.
But apparently to me \infty \cdot 0 = 0 should be adopted
Else, if f admit \infty on set A of measure 0, we may use f_{n} = n on A to approximate f from below, then, the integral of f_{n} is zero, by monotone convergence theorem, the integral of f should be zero as well. If we do not define \infty \cdot 0 = 0, we may get inconsistency in this case?
But what if the f_{n} are defined over sets of measure non-zero, but that the sum of the measure of those sets converges to zero?
Boot20 said:
But what if the f_{n} are defined over sets of measure noe intgen-zero, but that the sum of the measure of those sets converges to zero?
Sorry that I cannot get your idea exactly. Or can you tell me explicitly what is the function f to be integrated?
