Integrating Height as a Function of Time: Help Needed
  • Thread starter Thread starter sicjeff
    Integration
15 replies · 2K views
sicjeff
I am having difficulty in integrating this one. My objective is to find height as a function of time; however each time I actually do the integration, I end up with being able to find height as a function of both time and height. I have attempted using Maple to find a unique solution but it produces a (Lambar delta) (possible spelling error). Here is my integration.
int(t)=int([8(mu)(h)]/[2(sigma)(g)(r)-(rho)(g)(h)(r^2)] dh
I keep getting non real answers when I plug in values. Sigma is a surface tension but it keeps getting caught into natural logs with a negative value(impossible)
Any help would be quite appreciated.
What are you trying to do here??
Is it to find the anti-derivative:
[tex]I=\int\frac{8\mu{h}}{2\sigma{gr}-\rho{gh}r^{2}}dh[/tex]
If so, what are constants, and what is variable quantities with respect to which variables?
the only variables are time and height. The others are constants.
a non changing radius.
I will define all variables
t=time
h=height
r=radius
mu= fluid viscocity
sigma=surface tension
g=gravitational force
rho= density
the integral of t from t=0 to t so basically the left hand side of the equation reduces to t.
The expression [itex]\int_{0}^{t}tdt[/itex]?
First of all, your notation is a meaningless conjunction of integration variable and limit of integration, nor would it in this abuse of notation equal t.
Are you sure your left-hand side shouldn't be [itex]\int_{0}^{t}d\tau=t[/itex]?
right I forgot to say with what respect I was integrating the left hand side, but I am sure that the left hand side reduces to t.
I agree with the first equation that you posted except the left hand side should be t instead of I. the limits of integration from the right side are h= 0 to h=h(final)
Okay, so what your ACTUAL equation should be is:
[tex]t=\int_{0}^{h(t)}\frac{8\mu{H}}{2\sigma{gr}-\rho{gH}r^{2}}dH[/tex]
That, at the very least, is a mathematically meaningful expression.
Is that what you meant?
yes. I'm sorry, but I don't know how to use the equation editor
I'm sorry I don't guess I follow you. That isn't something that I have seen in my undergraduate mathematics.
okay, now I see. Thanks. I can do that integration quite easily.
