Integrating to an absolute value?
Blastrix91
I need some help understanding an integral step in the example below. I get how the integrand was set up, but I don't get how comes to two expressions with the absolute value of z-L/2.
(Problem description if that is needed: L is the length of a cylinder with radius R, and P is the polarization of the cylinder in direction of its length. Calculate the electric field at a point on the axis of the rod)
http://imageshack.us/a/img594/1895/absolutevalue.png
I don't understand that step really. Google has no answers. I thought that it might have been some absolute value identities, but it seems that was not the case. Is there someone who'd lend a hand?
\int_0^R \frac{r}{\sqrt{r^2+a^2}} dr <br /> = \frac{1}{2} \int_{r=0}^R \frac{d(r^2)}{\sqrt{r^2+a^2}}<br /> = \frac{1}{2} \int_0^{R^2} \frac{dy}{\sqrt{y+a^2}} = \left. \sqrt{y+a^2}\right|_0^{R^2} Look at what you get if a > 0 or a < 0.
RGV
It's because, \displaystyle \sqrt{u^2}=|u|\ .
Wow thank you. That was pretty helpful
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
