Integration by change to polar coordinates
The discussion revolves around the process of changing to polar coordinates in a multi-dimensional integral involving a Heaviside step function. Participants explore the implications of this transformation on the integral's evaluation and seek alternative methods for simplification.
  • One participant presents an integral and expresses concern about the presence of factors from the Jacobian in the polar coordinate transformation, questioning if there is a simpler method to evaluate the integral.
  • Another participant clarifies the necessity of the r factor in the differential when switching to polar coordinates, emphasizing its role in maintaining dimensional consistency.
  • A suggestion is made to use a substitution involving squares of the radial coordinates, leading to a different form of the integral.
  • Further discussion includes the idea of adjusting integration limits to potentially eliminate the Heaviside function from the integral.
  • One participant claims to have found a solution, identifying the integral as the volume of a simplex in 3N dimensions, which is a known result in simplex analysis.
  • Several participants express curiosity about the mathematical concepts involved, particularly the notion of a simplex and its relevance in linear programming.
Participants do not reach a consensus on the best method for evaluating the integral. While one participant claims to have found a solution, others continue to explore alternative approaches and express uncertainty about the transformations and substitutions discussed.
Some participants note the importance of defining terms such as the Heaviside step function, which affects the interpretation of the integral. The discussion also highlights the complexity of changing variables in multi-dimensional integrals and the need for careful consideration of limits.
This discussion may be of interest to students and professionals in mathematics, physics, and engineering, particularly those dealing with advanced calculus, integration techniques, and geometric interpretations of integrals.
M.B.
Hey,
I have the following integral:
[tex] <br /> I = \int_0^\infty dx_1\ldots \int_0^\infty dx_{3N} \int_0^\infty dy_1\ldots \int_0^\infty dy_{3N}\Theta\left(1-\sum_{j=1}^{3N}\left(|x_j|^2+|y_j|^2\right)\right)<br /> [/tex]
Now I want to change to polar coordinates by the following substitution:
[tex] <br /> \begin{equation}<br /> x_j &=& r_j \cos \varphi_j;<br /> y_j &=& r_j \sin\varphi_j<br /> \end{equation}<br /> [/tex]
Then the integral becomes
[tex] <br /> \left[\int_0^{2\pi}d\varphi\right]^{3N}\int_0^\infty dr_1\ldots \int_0^\infty dr_{3N}r_1r_2\ldots r_{3N} \Theta\left(1-\sum_{j=1}^{3N}|r_j|^2\right)<br /> [/tex]
Now this factors [itex]x_j[/itex] in front of the theta function are bothering me, because if they weren't there, the integral would be simply the volume of sphere with radius 1 in 3N dimensions, and this is a known formula.
But, they are there so this is a problem...
Or not, I don't know, is there another maybe easier way to solve this integral?
Is my substitution perhaps not wel chosen?
(there are some typo's in the formula, but not important, seems like the preview doesn't renew the latex code)
I don't see any xj only rj, which makes perfect sense.
My bad...
I mean the [itex]r_j[/itex](instead of [itex]x_j[/itex]) coming from the jacobian due to the coordinate transformation.
I wish they weren't there because the integral would be a volume of a 3N-sphere.
Is there more advance that can be made otherwise?
For better or worse, switching from rectangular to polar coordinates will always look like:
dxdy = rdrdφ. Intuitively you can look at the r factor being necessary to preserve the dimension of the differential as length squared.
Yes, of course.
Is there maybe anothor way to factorize the original integral in x and y so that I can solve it an a closed form?
The change to polar coordinates seemed logical to me because I would get a product of two indepent integrals.
You hadn't defined Θ, so I couldn't answer.
[itex]\Theta[/itex] is Heaviside's stepfunction, equals 1 when it's argument is larger than zero, and 0 otherwise.
That's why it would be the volume of a sphere with radius 1 when being factorized without the r_j in front
Have you tried u_j=r_j2? Then let v=Σu_j and play with the limits.
The substitution [itex]r_j^2=u_j[/itex]
leads,
for the r-integral only,
to
[tex]\frac{1}{2^{3N}}\int_0^\infty du_1\ldots \int_0^\infty du_{3N}\Theta\left(1-\sum_{j=1}^{3N}|u_j|\right)[/tex]
Playing with the limits... I don't see exactly what you mean.
I was suggesting a change of variables where w=Σuj replaces one of the u's. Now the problem is adjusting the integration limits to accommodate the change of variable.
I still don't get it.
I think you mean this the following?
[tex] \frac{1}{2^{3N}}\int_0^\infty du_1\ldots \int_0^\infty du_{3N}\Theta\left(1-\sum_{j=1}^{3N}|u_j|\right)<br /> [/tex]
with the substitution [itex]w=\sum_j u_j[/itex] you get [itex]dw = \sum du_j[/itex]. How exactly do you enter this differential in the integral then...this become nested integrals then?
No! I meant substitute w for (for example) u1, so dw =du1, while all the other u's remain the same. As a result, the problem then becomes setting up the appropriate integration limits.
One further suggestion (possible alternative) - try setting up the integration limits so that you can dispense with the Heaviside function. Then u1 has limits (0,1), u2 has limits (0,1-u1), u3 has limits (0,1-u1-u2), etc. Then you won't need any change of variables. It looks like a somewhat messy arithmetic problem.
I finally found the solution. The surface ∑uk=1 is a simplex in 3N dimensions. Your integral is the volume between 0 and the simplex (with all sides limited to uk ≥ 0). This happens to be a solved problem in simplex analysis (V = 1/(3N)!). It is relatively easy to prove by induction.
http://en.wikipedia.org/wiki/Simplex
Thank you for it!
I didn't even know it was a known "standard"-integral.
Even never heard of simplex...
A simplex is an n dimensional surface with ∑uk=1 and all uk non-negative.
Just curious, but what kind of course is this? I'm finding these advanced calculus topics interesting, but I don't know what they're called. Is it analysis?
Thanks for the link mathman. What I meant by course was where do people learn about this kind of math? i.e. what's it called? I've taken up to Calc III and diff eq so far, but I haven't seen anything like this.
I've taught linear programming in a PreCalculus course- since it doesn't involve any calculus. However, an "n-Simplex" can be defined as "the convex hull of n+ 1 points" where "convex hull" of any number of points is the set that contains all the points and all straight line segments between them.
A "1-simplex" is the straight line segment between two points. A "2-simple" is the triangle having three given points as vertices. A "3-simplex" is the tetrahedron having four given points as vertices.
  • · Replies 19 ·
12K
  • · Replies 41 ·
