Integration by parts SinIntegral[x]
The integral ∫0t SinIntegral[x] dx can be approached using integration by parts, but it may require applying the method twice. Initially, setting u[x] = SinIntegral[x] and v'[x] = 1 simplifies the problem to tSinIntegral[t] - ∫0t Sinc[x] dx. Understanding that Sinc[x] is defined as Sin[x]/x helps clarify the integration process. The final expression can be simplified to tSinIntegral[t] - (Sin[t] - 1), leading to a more manageable solution. The discussion emphasizes the importance of recognizing the Sinc function's definition for solving the integral effectively.
eclayj
Calculate the following integral exactly (no approximations) by the method of integration by parts:
the following hints are given:
D[SinIntegral[x], x] = Sinc[x]; and
SinIntegral[0] = 0
The integration by parts forrmula is ∫abu[x]v'[x]dx = u[x]v[x]|ab-∫abv[x]u'[x]dx.
The problem I have is that whether I let u[x]=1 and v'[x]= SinIntegral[x], or u[x]=SinIntegral[x] and v'[x]= 1, either way the integral on the right is more complex than what I started with (either ∫0txSinc[x]; or ∫0tSinIntegral[x].
Any help is appreciated. I hope all the programming tags work here, otherwise this will look like a mess. It may still look like a mess
So it seems to me that, although the question requires the differentiation by parts method, such method does not work because it you get more complicated integrals
Wait, maybe I undertstand it. Do you have to use integration by parts method twice? i.e., letting u[x] = SinIntegral[x], and v^\[Prime][x] = 1; u^\[Prime][x] = Sinc[x] ; v[x] = x
Which after applying the formula would get you to tSinIntegral[t] - ∫0tSinc[x]dx.
Then you run the integration by parts once again to find n = ∫0tSinc[x]dx.
Then the final answer will be tSinIntegral[t] - n?
This seems a little tedious, but the question specifically asks you to use the integration by parts formula, so I am guessing this must be it, unless I am missing something obvious... which is usually the case.
nope. Still stuck
Do you know what Sinc(x)․x is ?
Thanks Sammy. I had never encoutered the Sinc Function before. After your hint, and a little help from google, I found that Sinc[x]= (Sin[x])/x. So xSinc[x] should be Sin[x], which makes the problem much easier. I think that should have been another hint given, I'm only working in Calc II ;).
Is it sin int(t)*t+cos(t)-1? since D(sin int(x))=sinc(x)=sin(x)/x, u=sin int(x). If you look a int^udv=uv-int^v*du, du is on the RHS.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 105 ·
  • · Replies 22 ·
