MHB Ready to Tackle an Advanced Calculus Challenge?
The discussion revolves around evaluating the integral $$\int_0^{\frac{\pi}{2}}\frac{\log \tan \theta}{\sqrt{1+\cos^2 \theta}}d\theta$$ and demonstrating its equivalence to another integral form. Participants highlight the use of transformations and substitutions, particularly involving the tangent function and elliptic integrals, to simplify the problem. The solution ultimately connects to known results involving the Gamma function and elliptic integrals, revealing a complex relationship between these mathematical entities. A modified version of the integral is proposed for further exploration, adding to the challenge. The conversation showcases advanced techniques in calculus and integral evaluation.
Shobhit
Show that
$$\int_0^{\frac{\pi}{2}}\frac{\log \tan \theta}{\sqrt{1+\cos^2 \theta}}d\theta = \frac{\log 2}{16 \Gamma \left(\frac{3}{4} \right)^2}\sqrt{2\pi^3}$$
This integral is harder than the http://mathhelpboards.com/challenge-questions-puzzles-28/integration-challenge-7720.html. :D
Mathematics news on Phys.org
I'm just going to show that it is equivalent to another definite integral.
$$ \int_0^{\pi /2}\frac{\log ( \tan x) }{\sqrt{1+\cos^2 x }}\ dx = \int_{0}^{\pi /2} \frac{\log (\tan x)}{\sqrt{2-\sin^{2} x}} \ dx = \frac{1}{\sqrt{2}} \int_{0}^{\pi /2} \frac{\log(\tan x)}{\sqrt{1- \frac{1}{2} \sin^{2} x}} \ dx $$Let $ u = \tan x$.$$ = \frac{1}{\sqrt{2}} \int_{0}^{\infty} \frac{\log u}{\sqrt{1- \frac{1}{2} \frac{u^{2}}{1+u^{2}}}} \frac{1}{1+u^{2}} \ du = \int_{0}^{\infty} \frac{\log u}{\sqrt{\frac{2+u^{2}}{1+u^{2}}}} \frac{1}{1+u^{2}} \ du = $$
$$ = \int_{0}^{\infty} \frac{\log u}{\sqrt{(1+u^{2})(2+u^{2})}} \ du = \int_{0}^{\infty} \frac{\log u}{\sqrt{(1+u^{2})(1 - i^2+u^{2})}} \ du $$There is a formula that states $$ \int_{0}^{\infty} \frac{\log x}{\sqrt{(1+x^{2})(1-k^{2} + x^{2})}} \ dx = \frac{1}{2} K(k) \ln( \sqrt{1-k^{2}})$$
where $K(k)$ is the complete elliptic integral of the first kind.A derivation in one of Victor Moll's papers uses a crazy-looking hypergeometric identity.So anyways
$$ \int_0^{\pi /2}\frac{\log ( \tan x) }{\sqrt{1+\cos^2 x }}\ dx = \frac{1}{2} K(i) \ln (\sqrt{2}) = \frac{\log 2}{16 \sqrt{2 \pi}} \Gamma^{2} \left( \frac{1}{4} \right)$$
which by the Gamma reflection formula is equivalent to the answer given
Not surprised to see elliptic integrals and hypergeometric functions involved. I tried to solve it with no success.
Well done RV! :)
Now, I am going to modify this problem slightly to make it even more challenging.Show that
\int_0^{\pi\over 2}\frac{\log(\tan x)}{\sqrt{2} \sin(x)+\sqrt{1+\sin^2 x}}dx = \frac{1}{\sqrt{2\,\pi}}\left(1+\frac{\log 2}{4} \right)\Gamma\left(\frac34\right)^2-\frac{\sqrt{2\,\pi^3}}{8\Gamma\left(\frac34\right)^{2}}+(\log 2-1)\,\sqrt2
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
