Finding a in circular motion problem
The discussion centers on a physics problem involving a stone released from a sling in circular motion. The user initially misapplies the free fall equation to determine time and velocity but is corrected to focus on the principles of circular motion. The correct approach involves using the equations of motion to find the stone's velocity at release and then applying the formula for centripetal acceleration, a = v²/r. The confusion about the expected answer being 160 m/s is clarified, with the correct unit being 160 m/s² for acceleration. Ultimately, the user resolves the issue by properly applying the relevant formulas for circular motion.
infraray
The problem is this: sling with r=1.5m spinning 2m above ground. Stone is released and lands 10m away. What is acceleration while in circular motion? The answer is supposed to be 160 m/s. I keep coming up with approx. 145 m/s. I assume I am to figure t first to then find v, where t= sqrt(2y/g), which yields approx. 0.64s. Where am I going wrong? I have tried this many different ways and am pulling my hair out. Any help or leads will be greatly appreciated. Thanks.
That equation is for free fall, not for circular motion.
The acceleration of a particle undergoing uniform circular motion is
aC=v2/r. You need to know how fast the mass is moving.
Maybe I am missing something, but the problem isn't doesn't contain velocity as a given, the only givens are: r=1.5m, y=2m, and x=10m. I assume I am to figure out the initial v as the stone leaves the sling and work backward to find a. Once again I preemtively thank anyone who can offer some advice.
You know the height of the stone when it is "released" from the sling and you know it was moving horizontally at that time. The motion of the stone from that point is y= (-g/2)t^2+ 2 and x= v t.
You know that when y= 0, x= 10 m. You should be able to solve the equations (-g/2)t^2+ 2= 0 for t (yes, t= sqrt(2y/g) which, since y= 2, is t= 2/sqrt(g)) and then v t= 10 for v. THAT gives you the speed of the stone. Knowing that you can use the formulas for circular motion (particularly a= v^2/R) to find the acceleration, a.
By the way, you say that "The answer is supposed to be 160 m/s."
Of course, that's impossible: I'm sure you mean 160 m/s^2.
Actually, I get 163 1/3 meters per second squared.
Thanks HallsofIvy! What was messing me up was trying to calculate the velocity by using the formula v=c/t where c is the circumference. I was assuming that because I was looking for the acceleration while in circular motion I should have been using that formula. It all works out fine now. Oh, yeah I realize the 160 m/s should have contained the square I apparently did not proof read well enough. Thanks again for your help.
