Integration - problems with defining the original function
kapitan90
Hi,
I am supposed to integrate <br /> \frac{1}{(x^2 + 2x +5)}<br />
In my textbook the method of arctan is used.
I wonder why I can't define y as the logarithmic function instead.
y = ln (x^2 + 2x +5) / (2x+2)
with absolute value in ln.Can both methods be used?
When I compare graphs for ln and arctan they are equivalent despite x close to the y - axis.
kapitan90 said:
Hi,
<br /> \frac{dy}{dx}= \frac{1}{x^2 + 2x +5()}<br />
No. To take the derivative of y = ln (x^2 + 2x +5) / (2x+2) you need to use the quotient rule. The result isn't 1/(x^2+2x+5).
Ok, I see that it's incorrect. So can we generalize that to use direct reverse method with natural logarihm the integrated function needs to have a form:
<br /> <br /> \frac{af&#039;(x)}{f(x)}<br /> <br />
and ln(f(x)) - method is basically invalid for all other forms?
Yes, that is the same as the standard integration formula:
\int \frac{du}{u}= ln(c)+ C
with f(x) instead of u.
To integrate
\int \frac{dx}{x^2+ 2x+ 5}
I suggest you complete the square in the denominator to get a standard form.
Ok, now I get it, thanks for help!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
