Integration using Beta and Gamma Functions
200 replies · 32K views
ZaidAlyafey said:
The lower and upper limits before the substitution were $0$ and $1$ consecutively. If we make the substitution they are $\infty$ and $1$. You have the choice between $x$ and $t$. Remember if we have an improper integral we take the limit
$$\int^\infty_1 f(x) \,dx = \lim_{t \to \infty }\int^t_1 f(x) \,dx$$
Hello,
@ZaidAlyafey, I hope you did not misunderstand that I was trying to ignore you. I did indeed read this reply, but I stood off for a while, getting more in depth with this topic, so now I can discuss this. Please do not mind, I appreciate every bit and I won't give up on this, until I figure it out! =)
I have labeled sections of questions, I would appreciate if you respond to each section separately.
QUESTION #1:
You had this: (We were trying to evaluate $\psi(1)$ as an example)
$\displaystyle \sum_{n=1}^\infty \frac{z^{2n}}{n} = -\log(1-z^2)$
How did you arrive at this result?
QUESTION #2:
Secondly: You stated the following:
$\displaystyle \sum_{n=1}^\infty \frac{z^{2n-1}}{n(2n-1)} = -\int^z_0\frac{\log(1-x^2)}{x^2}\,dx$
But you did not integrate the LHS. Can you take me behind the scenes here?
QUESTION #3:
Please tell me. Can you write sums as integrals for every sum? If so, how? Thanks!
Final comment:
Again, you did not give up on me, and I did not give up on you either! I just took a break so I could read more (as you have seen from my posts). Please do not mind this, I try not to give up on anything! Thanks for your dedication.
Olok said:
QUESTION #1:
Ok we start by the following
$$\sum_{n=1}^\infty x^{n-1} = \frac{1}{1-x}$$
Then integrate to get
$$\sum_{n=1}^\infty \frac{x^n}{n} =- \log(1-x)$$
Finally let $x= z^2$
QUESTION #2:
From the first part we proved that
$$\sum_{n=1}^\infty \frac{z^{2n}}{n} = -\log(1-z^2)$$
Now divide by $z^2$ to obtain
$$\sum_{n=1}^\infty \frac{z^{2n-2}}{n} = -\frac{\log(1-z^2)}{z^2}$$
Now integrate with respect to $z$
$$\sum_{n=1}^\infty \int^z_0 \frac{z^{2n-2}}{n} \,dz= -\int^z_0\frac{\log(1-z^2)}{z^2}\,dz$$
QUESTION #3:
Definite integrals are Riemann sums , so it must be possible but might be complicated. Moreover , it will not necessarily make the problem easier to solve.
Final comment:
It is good that you took your time trying to understand series.
It has been known that:
QUESTION #1:
$\displaystyle \sum_{n=0}^{\infty} r^n = \frac{1}{1-r}$
Let $u = n-1$ so
$\displaystyle \sum_{n=1}^{\infty} x^{n-1} = \sum_{u=0}^{\infty} x^{u} = \frac{1}{1-x}$
Is this how you derive that result?
QUESTION #2:
About interchanging summation and integral, doesn't the series have to be a monotone series? How did you test if that series was monotone?
QUESTION #3:
You cannot simply get $\psi(1)$ just be evaluating the integral. The LHS is NOT the proper definition of the digamma $\psi$ function. Wikipedia states:
$\psi(z) = \gamma + \displaystyle \sum_{n=1}^{\infty} \frac{z}{n(n+z)}$
So what next?
Thanks Zaid!
QUESTION #1:
Let $u = n-1$ so
Yes , exactly.
QUESTION #2:
The function is a geometric series , so you can integrate term by term.
QUESTION #3:
Revise post #23.
ZaidAlyafey said:
Yes , exactly.
Revise post #23.
Hello, I just reread that post (long time ago!)
So let $z = 1$ then you have the required sum? That makes sense.
I suppose you have tons of practice with this stuff. I just can't think like that. Perhaps its the lack of my practice (maybe due to my age). Thanks though. Let's try another one?
$\psi(4) = \psi(3 + 1)$, so $z = 3$
$\psi(z+1) = \gamma + \displaystyle \sum_{n=1}^{\infty} \frac{z}{n(n+z)}$
When $z = 3$, $\psi(3+1) = \gamma + \displaystyle 3\sum_{n=1}^{\infty} \frac{1}{n(n+3)}$
$\displaystyle \sum_{n=0}^{\infty} x^n = \frac{1}{1-x}$
$\displaystyle \sum_{u=2}^{\infty} x^{u} = \frac{1}{1-x} - (x + x^2)$
Where $u = n + 2$
$\displaystyle \sum_{u=2}^{\infty} \int_{0}^{z-3} x^{u} \,dx = \int_{0}^{z-3} \frac{1}{1-x} - (x + x^2) \,dx$
$= \displaystyle \sum_{u=2}^{\infty} \frac{(z-3)^{u+1}}{u+1} = \int_{0}^{z-3} \frac{1}{1-x} - (x + x^2) \,dx$
$= \displaystyle \sum_{n=0}^{\infty} \frac{(z-3)^{n+3}}{n+3} = \int_{0}^{z-3} \frac{1}{1-x} - (x + x^2) \,dx$
$= \displaystyle \sum_{n=0}^{\infty} \frac{(z-3)^{n+3}}{z(n+3)} = \displaystyle \frac{\int_{0}^{z-3} \frac{1}{1-x} - (x + x^2) \,dx}{z}$
Anything that may help?
Thanks!
We have already proved that
$$\sum_{n=1}^\infty \frac{z^n }{n} = -\log(1-z)$$
Multiply by $z^2$ to get
$$\sum_{n=1}^\infty \frac{z^{n+2} }{n} = -z^2\log(1-z)$$
Now integrate
$$\sum_{n=1}^\infty \frac{z^{n+3} }{n(n+3)} = -\int^z_0 x^2\log(1-x)\,dx$$
Now set $z=1$
$$\sum_{n=1}^\infty \frac{1 }{n(n+3)} = -\int^1_0 x^2\log(1-x)\,dx$$
That should be easy solvable using $t = 1-x$.
Note you can also use
$$\psi(z+1) = \psi(z)+\frac{1}{z}$$.
Now integrate
$$\sum_{n=1}^\infty \frac{z^{n+2} }{n(n+3)} = -\int^z_0 x^2\log(1-x)\,dx$$
Now set $z=1$
That is fantastic. Let's find
$\psi(5/4) = \psi(1 + 1/4)$ therefore, $z = 1/4$
There is one issue with the integration (not yours but in general).
When you integrate you change the $Z$'s in the integrand to $x$'s. But you do not do the same on the RHS. When you do:
Now integrate
How?
Let us see what you have tried.
How?
I made a mistake it should be
$$\sum_{n=1}^\infty\frac{z^{n+3}}{n(n+3)} =- \int^z_0 x^2\log(1-x)\,dx$$
Since it is a dummy variable you can use $z$ but I am trying to avoid confusion. The following is also correct
$$\sum_{n=1}^\infty\frac{z^{n+3}}{n(n+3)} = -\int^z_0 z^2\log(1-z)\,dz$$
So then,
Let $z = 1$ On the RHS you have,
$$\sum_{n=1}^\infty\frac{1}{n(n+3)} = -\int^1_0 \log(1-1)\,dz$$
which is not possible.
Olok said:
So then,
This is where a confusion happens. The inner $z$ is independent of the outer $z$ so to avoid that we always avoid such symbols. The inner $z$ is a dummy variable so we can choose any thing we want $x$ , $y$ or even $z$. So it is always preferable to use a symbol different than the boundary of integration for example $x$
$$\int^z_0 x^2\log(1-x)\,dx$$
Why not just avoid all confusion, and directly integrate form 0 to 1?anyway,
$\psi(5/4), z = 1/4$
$\displaystyle \sum_{n=1}^{\infty} \frac{x^n}{n} = -\ln(1-x)$
Let $x = z^4$
$\displaystyle \sum_{n=1}^{\infty} \frac{1}{n(4n+1)} = -\int_{0}^{1} \ln(1-z^4) \,dz$
So we must figure out $\displaystyle -\int_{0}^{1} \ln(1-z^4) \,dz$ then add $\gamma$ to it. The integral is tough though.
The antiderivative is too intense to even look at. How would you evaluate the integral?
Out of curiosity, can you get a closed-form by using series. Maybe that could help. I was looking at the challenges section of the forum.
One of them is your logarithmic integral #3, which remains unsolved..
I just had a thought... if you don't mind, maybe we can try the integral, since no one has done it in two months or is that not allowed? Thanks.
Sure , that might be better :)
anyway,
Let $x = z^4$
It might not be as tought as you think , use the property
$$(1-z^4) = (1-z)(1+z)(1+z^2)$$
I just had a tough... if you don't mind, maybe we can try the integral, since no one has done it in two months or is that not allowed? Thanks.
Can you give me the link ?
Hey there!
$\displaystyle \log((1-z)(1+z)(1+z^2)) = \log(1-z) + \log(1+z) + \log(1+z^2)$
$\displaystyle \int_{0}^{1} \log((1-z)(1+z)(1+z^2)) \,dz = \int_{0}^{1} \log(1-z) + \log(1+z) + \log(1+z^2) \,dz = \lim_{z\to 1} -(1-z)(\log(1-z) - 1) + (1+z)(\log(1+z) - 1) + \int_{0}^{1} \log(1 + z^2) \,dz$
Currently, I am running out of sleep, so I'll continue the integration tomorrow. Please do not give hints, just let me know if the setup is correct. Thanks.
NEXT:
The integral was: http://mathhelpboards.com/challenge-questions-puzzles-28/not-solved-logarithm-integral-3-a-12050.html
I spent hours and hours trying this, but later find out it requires special functions...
Question #1:
Do you know where I can get a quick course on special functions and more IMPORTANTLY, how to implement them into integration?
Functions such as $\zeta(s), L_1, L_2$ I am not sure what the ones with the $L$ are, supposed logarithmic integrals for $\frac{1}{\ln(x)}$ But perhaps you could guide me to somewhere they talk about this and how to implement this in depth.
Question #2:
You posted a hint there as well. I assume you want me to integrate the series, LHS, RHS to get it into some sort of form?
Question #3:
What is that series anyway? I am not familiar with the $H_kx^k$ idea or what It is. I tried putting it online, but no result?
Question #4:
Can you perhaps show me a page where they talk about all these laws, such as the one with dilogs etc shown here: http://mathhelpboards.com/calculus-10/higher-order-reflected-logarithms-13087.html
Thank you @ZaidAlyafey, I appreciate your guidance here in this forum, it is highly valuable to me! Thanks a bunch =)
Olok said:
Hey there!
Let me see the full solution.
NEXT:
There are many ways to solve that integral. You can solve it using the beta function. It is a good practice , try it .
Question #1:
These are called dilogarithms. I discussed lots of special functions on this http://mathhelpboards.com/calculus-10/advanced-integration-techniques-3233-post14488.html#post14488.
Question #2:
Exactly.
Question #3:
$H_k$ is called the harmonic number. The series containg them are called Euler sums.
Question #4:
You can refer to the link above on Advanced integration techniques. In this http://mathhelpboards.com/calculus-10/advanced-integration-techniques-3233-post23071.html#post23071I discuss polylogarithms.
Exactly.
The improper integrals must be divergent. The limit cannot exist because of $\ln(1-z)$ the limit as $x \to 1$ does not exist.
Question #1:
Also where did you learn special functions? What is a possible textbook, since i can access that offline. Your page was amazing but my Internet can't load all LaTex making it immensely hard to read. But I tried.
I read the page, I was able to prove the integral.
$\displaystyle Li_2(z) = \sum_{k=1}^{\infty} \frac{z^k}{k^2} = -\int_{0}^{z} \frac{log(1-x)}{x}\,dx$
$\displaystyle \sum_{n=1}^{\infty} {x}^{n-1} = \frac{1}{1-x}$
$\displaystyle \sum_{n=1}^{\infty} \frac{x^n}{n} = -\ln\left({1-x}\right)$
$\displaystyle \sum_{n=1}^{\infty} \frac{x^{n-1}}{n} = \frac{-\ln(1-x)}{x}$
$\displaystyle \sum_{n=1}^{\infty} \frac{z^n}{n^2} = \int_{0}^{z} \frac{-\ln(1-x)}{x} \,dx$
Let me know.
Question #2:
How can you integrate $Li_2$? I tried from $0 \to 1$
$\displaystyle \int_{0}^{1} Li_2(z) \,dz = \sum_{n=1}^{\infty} \frac{1}{n^2(n+1)}$
$$\frac{An + B}{n^2} + \frac{D}{n+1} = \frac{1}{n^2(n+1)}$$
$$(An + B)(n+1) + D(n^2) = 1$$
Let $n = -1, \implies D = 1$
Let $n = 0, \implies B = 1$
Let $n = 1, \implies A = -1$
$$\frac{-n + 1}{n^2} + \frac{1}{n+1} = \frac{1}{n^2(n+1)}$$
$$= \sum_{n=1}^{\infty} \frac{-n + 1}{n^2} + \frac{1}{n+1} = \sum_{n=1}^{\infty} \frac{1}{n^2(n+1)} = \sum_{n=1}^{\infty} \frac{1}{n^2} - \frac{1}{n} + \frac{1}{n+1} $$
The $1/n$ is the problem, it is the harmonic series, which diverges.
Thanks (BTW: Where did you find the dilog reflection law?)
Thanks =)
I must see your full solution. If you are talking about $\int^1_0\log(1-z)dz$ then this integral converges and it is value is $-1$.
Question #1:
Oh , that is so bad. Unfortunately , I learned each special function separately by searching the internet about its properties. I don't reckon seeing a book that explains all special functions.
Let me know.
That is good , you are making a big progress.
Question #2:
Very nice. Now separate the sum into
$$\sum \frac{1}{n^2 }+\sum \frac{1}{n+1}-\frac{1}{n}$$
The right is a telescoping series , isn't it ?
Thanks =)
http://mathhelpboards.com/challenge-questions-puzzles-28/dilogarithmic-integration-parts-10876.html?highlight=reflectionare two proofs.
Thank you ZaidAlyafey, you are a very encouraging person, which I appreciate. I appreciate your help here as well, I have learned a lot from you, especially about series.
I went to the proof page. I read your proof, it was very nice :D But it stated,
take $x = 1$ we get C = $Li_2$, but how? What is $f(x)$ if $x = 1$? I won't be defined.
The integral first.
I need $\displaystyle \int_{0}^{1} \ln(1+ z^2) \,dz$ But the question is how...
$\displaystyle \int_{0}^{1} \ln(1+ z^2) \,dz = ?$
I am thinking of a strategy for this. I checked WolframAlpha. The integral is quite intense, I think by parts is the best idea.
It was intense, I did it on paper. I ran into a loop, typing it would be very hard, I'll do the last few steps here.
$I = \displaystyle x\ln(1 + x^2) - 2x^2\arctan(x) + 4[x(x\arctan(x) - 0.5\log(1+x^2)) - \int (x\arctan(x) \space dx) + 0.5I]$
$-I = \displaystyle x\ln(1 + x^2) - 2x^2\arctan(x) + 4[x(x\arctan(x) - 0.5\log(1+x^2)) - \int (x\arctan(x) \space dx)]$
$I = \displaystyle -x\ln(1 + x^2) + 2x^2\arctan(x) - 4[x(x\arctan(x) - 0.5\log(1+x^2)) - \int (x\arctan(x) \space dx)]$
Finally,
$I_{Final} = \displaystyle \lim_{{z}\to{1}} -(1-z)(\log(1-z) - 1) + (1+z)(\log(1+z) - 1) + [(-1\ln(2)) + 2\arctan(1) - 4[\arctan(1) - 0.5\log(2) - \int_{0}^{1} x\arctan(x) \,dx]]$
$I_{final} = \displaystyle \lim_{{z}\to{1}} -(1-z)(\log(1-z) - 1) + (1+z)(\log(1+z) - 1) + [-\log(2) + \pi/2 - 4[\pi/4 - \log(\sqrt{2}) - \int_{0}^{1} x\arctan(x) \,dx]]$
$I_{final} = \displaystyle \lim_{{z}\to{1}} -(1-z)(\log(1-z) - 1) + (1+z)(\log(1+z) - 1) + [-\log(2) + \pi/2 - \pi + \log(4) - 4\int_{0}^{1} x\arctan(x) \,dx]]$
$I_{final} = \displaystyle \lim_{{z}\to{1}} -(1-z)(\log(1-z) - 1) + (1+z)(\log(1+z) - 1) + [\log(2) - \frac{\pi}{2} - 4\int_{0}^{1} x\arctan(x) \,dx]]$
$$2\int x\arctan(x) \,dx = x^2\arctan(x) - (x/2)\log(1+x^2) + 0.5\int log(1 + x^2)$$
Ahhh this is crazy. So much going around, now I am back at the log(1+x^2) integral... Can this be done otherwise?
Lets try the: http://mathhelpboards.com/challenge-questions-puzzles-28/not-solved-logarithm-integral-3-a-12050.html integral.
$\displaystyle \int_{0}^{1} \log^2(x)\log^2(1-x) \,dx$
So $\displaystyle \sum_{k=1}^{\infty} H_kx^k = \frac{-\log(1-x)}{1-x}$
$$\sum_{n=1}^{\infty} x^{n-1} = \frac{1}{1-x}$$
$$\sum_{n=1}^{\infty} -\log(1-x)x^{n-1} = \frac{-\log(1-x)}{1-x}$$
If it has to do with integration of $H_k$ then I have no clue. Well, I sort of do.
$\displaystyle H_k = \sum_{n=1}^{k} \frac{1}{n}$
$\displaystyle (H_k)(x^k) = \sum_{n=1}^{k} \frac{x^k}{n}$
$\displaystyle \sum_{k=1}^{n} H_nx^n = \frac{-\log(1-x)}{1-x}$
$\displaystyle \sum_{k=1}^{\infty} \int_{0}^{z}H_k(x^k) \,dx = \int_{0}^{z} \frac{-\log(1-x)}{1-x} \,dx$
I have just one issue.
$H_k = \displaystyle \sum_{n=1}^{k} \frac{1}{n}$
$x^k = x^k$
$H_k (x^k) = \displaystyle \sum_{n=1}^{k} \frac{x^k}{n)$
$\displaystyle \sum_{k=1}^{\infty} \displaystyle \sum_{n=1}^{k} \frac{x^k}{n}$ is what we must figure out, which seems ultimately difficult.
using Fubini's and Tonelli's theorems,
$\displaystyle \sum_{k=1}^{\infty} \displaystyle \sum_{n=1}^{k} \frac{x^k}{n} = \sum_{n=1}^{k} \frac{1}{n} \sum_{k=1}^{\infty} \frac{x^k}{1}$
$\displaystyle \sum_{k=1}^{\infty} x^{k} = \frac{1}{1-x} - 1 = \frac{x}{1-x}$
$\displaystyle \sum_{k=1}^{\infty} \displaystyle \sum_{n=1}^{k} \frac{x^k}{n} = \sum_{n=1}^{k} \frac{1}{n} \sum_{k=1}^{\infty} \frac{x^k}{1} = \sum_{n=1}^{k} \frac{x}{(1-x)(n)} = \frac{xH_k}{1-x}$
Okay, I am confused.
How can you integrate $H_k$? It becomes extremely difficult. Any suggestions? Thanks
I started by setting
$$f(x) = \mathrm{Li}_2(x) + \mathrm{Li}_2(1-x)$$
Hence setting $x\to 1 $ we get
$$c = \lim_{x\to 1 } f(x) +\log(x)\log(1-x) = \mathrm{Li}_2(1) + \mathrm{Li}_2(0)+ 0 = \mathrm{Li}_2(1) =\sum \frac{1}{n^2} = \zeta(2)$$
The integral first.
Finally,
Maybe you are doing it the wrong way ? Integrate $dx$ and differentiate $\log(1+x^2)$
$x^k = x^k$
I am confused too :) . It will be difficult for you trying to solve many different problems using different approaches. Euler sums require a descent knowledge of polylogarithms. Let us stick with finding the integral by differentiating Beta ?
Maybe we can start out by and easier one
$$\int^1_0 \log(x)\log(1-x) \, dx$$
PS: Nice that you are trying to post your attempts :cool:
Thank you Zaid. I will post my attempts on the first integral (the one with $\ln(1-z^4)$) tomorrow, I want to try this second one now.
I actually asked $Li_2$ because of this, we notice that.
$\log(x)\log(1-x) = -Li_2(x) - Li_2(1-x) + \pi^2/6$
$$\int^1_0 \log(x)\log(1-x) \, dx = \int_{0}^{1} -Li_2(x) - Li_2(1-x) + \pi^2/6 \,d$$
$Li_2(x) = \displaystyle \sum_{k=1}^{\infty} \frac{x^k}{k^2}$
$\displaystyle \int_{0}^{1} Li_2(x) \,dx = \displaystyle \sum_{k=1}^{\infty} \int_{0}^{1} \frac{x^k}{k^2} \,dx = \sum_{k=1}^{\infty} \frac{1}{k^2(k+1)} $
$\displaystyle \sum_{k=1}^{\infty} \frac{1}{k^2(k+1)} = \sum_{k=1}^{\infty}\frac{1}{k^2} - \frac{1}{k} + \frac{1}{(k+1)}$
$\displaystyle = \zeta(2) + \sum_{k=1}^{\infty} \frac{1}{k+1} - \frac{1}{k}$
$\displaystyle \sum_{k=1}^{\infty} \frac{1}{k+1} - \frac{1}{k}$
$S_1 = \frac{1}{2} - 1 $
$S_2 = \frac{1}{2} - 1 + \frac{1}{3} - \frac{1}{2}$
$S_3 = \frac{1}{2} - 1 + \frac{1}{3} - \frac{1}{2} + \frac{1}{4} - \frac{1}{3}$
$S_n = -1 + \frac{1}{n+1}$
$\displaystyle \lim_{n\to\infty} S_n = -1$
$Sum_{final} = \zeta(2) - 1$
Next We go to $\Li_2(1-x)$
$\Li_2(1-x) = \displaystyle \sum_{k=1}^{\infty} \frac{(1-x)^k}{k^2}$
$\int_{0}^{1} \Li_2(1-x) \,dx = \displaystyle \sum_{k=1}^{\infty}\int_{0}^{1} \frac{(1-x)^k}{k^2} \,dx$
$$ = \sum_{k=1}^{\infty} 0 = 0$$
because $Li_2(x)$ works for $0 < x < 1$,
$Li_2(1-x)$ should have domain $ 1 > x > 0$
So we take the limit as $x \to 1$ which is $-infty$ This is the hard part.
If I could get some help with $Li_2(1-x)$ I should be ready to roll!
Thanks. I would like to try the integral with Euler sums rather than differentiating Beta. Mostly because the Euler method is cool. And second, I have never learned multivariable calculus formally, just from some web reading, so when it comes to differentials (multivariable, will be required) I won't be able to do anything. So I would like to try euler sums!
Use \mathrm{Li}_p to display polylogarithms in a better way.
ZaidAlyafey said:
Could you rewrite that? It doesn't display well on my machine.
Its okay. I got it,
$\displaystyle \lim_{x\to 1} (1-x) = 0$
$Li_2(1-x) = Li_2(x) = \zeta(2) - 1$
$\displaystyle = \int_{0}^{1} -(\zeta(2) - 1) + \zeta(2) \,dx$
$\displaystyle = \int_{0}^{1} -2\zeta(2) + 2 + \zeta(2) \,dx$
$\displaystyle = \int_{0}^{1} 2 - \zeta(2) \,dx$
$= 2 - \zeta(2)$
Can we try the second power integral with Euler Sums ?? Please?
Olok said:
Its okay. I got it,
$= 2 - \zeta(2)$
Some how you got the idea but it should be like this
$$\int^1_0 \mathrm{Li}_2(1-t) \,dt = \int^1_0 \mathrm{Li}_2(x)\,dx $$
using the change of the variable $t = 1-x$.
Ok, but you have to revise your calculations and focus more. Let me see your second attempt.
Okay, I'll do a full version here:
$$\int_{0}^{1} \log(x)\log(1-x) \,dx$$
$$\log(x)\log(1-x) = -(L_2(x) + L_2(1-x)) + \zeta(2)$$
$$= \int_{0}^{1} -(L_2(x) + L_2(1-x)) \,dx + \zeta(2)$$
Evaluation of $\int_{0}^{1} L_2(x) \,dx$:
$$L_2(x) = \sum_{k=1}^{\infty} \frac{x^k}{k^2}$$
$$\int_{0}^{1} L_2(x) \,dx = \sum_{k=1}^{\infty} \frac{1}{k^2(k+1)}$$
$$= \zeta(2) + \sum_{k=1}^{\infty} \frac{1}{k+1} - \frac{1}{k^2}$$
$$S_1 = \frac{1}{2} - \frac{1}{1}$$
$$S_n = \frac{1}{n+1} - 1$$
$$\lim_{n\to\infty} S_n = -1$
Integral of $L_2(x) = \zeta(2) - 1$
Evaluation of $L_2(1-x)$:
The sum is exactly like the one as $L_2(x)$ so integral of $L_2(1-x) = \zeta(2) - 1$
Evaluation of all combined:
$$= \int_{0}^{1} -2(\zeta(2) - 1) \,dx + \zeta(2)$$
$$ = -2\zeta(2) + 2 + \zeta(2)$$
$$I_{final} = 2 - \zeta(2)$$
I began working on the power integral.
$$\int_{0}^{1} \log^2(x)\log^2(1-x) \,dx$$
$$\sum_{k=1}^{\infty} \frac{x^k}{k} = -\frac{\log(1-x)}{1-x}$$
$$\int\sum_{k=1}^{\infty} \frac{x^k}{k} \,dx = \int -\frac{\log(1-x)}{1-x} \,dx$$
Let $u = \log(1-x) \implies du = \frac{-1}{1-x} dx$
$$\int\sum_{k=1}^{\infty} \frac{x^k}{k} \,dx = \frac{\log^2(1-x)}{2} $$
$$\log^2(1-x) = 2\sum_{k=1}^{\infty} \frac{x^{k+1}}{k(k+1)}$$
We see that:
$$\sum_{k=1}^{\infty} \frac{z^k}{k} = -\frac{\log(1-z)}{1-z}$$
Let $z = 1 - x$, it guarantees $|z| < 1$
$$(-)\sum_{k=1}^{\infty} \frac{(x+1)^k}{k} = \frac{\log(x)}{x}$$
$$(-2)\sum_{k=1}^{\infty} \frac{(x+1)^{k+1}}{k(k+1)} = \log^2(x)$$
$$\int_{0}^{1} \log^2(x)\log^2(1-x) \,dx = (-4)\cdot\int_{0}^{1} \sum_{k=1}^{\infty} \frac{(x+1)^{k+1}}{k(k+1)})(\sum_{k=1}^{\infty} \frac{x^{k+1}}{k(k+1)})\,dx$$
So far so good?
$$= (-4)\cdot \sum_{k=1}^{\infty} \sum_{k=1}^{\infty} \int_{0}^{1} \frac{(x+1)^{k+1}}{k(k+1)}) \frac{x^{k+1}}{k(k+1)}) \,dx = (-4)\cdot \sum_{k=1}^{\infty} \sum_{k=1}^{\infty} (\frac{(2)^{k+1}}{k(k+1)}) - \frac{(1)}{k(k+1)}))(\frac{1}{k(k+1)}) = (-4)\cdot \sum_{k=1}^{\infty} \sum_{k=1}^{\infty} \frac{(2^{k+1} - 1)}{k^2(k+1)^2}$$
I must've done something wrong somewhwre.
Ah-Ha I found the mistake. I got the wrong square log.
It still won't be correct. I just can't get the squared log.
You should not write it like that. It should be
$$ -\int^1_0 L_2(x)dx- \int^1_0 L_2(1-x) dx = -2\int^1_0 L_2(x)dx = -2(\zeta(2)-1) $$
How did you get that ? are you missing the harmonic number ?
mmm... Why can't I write the integral like that? I just factored out a $(-1)$ Is that not correct?
Secondly.
I did miss out the harmonic number unforunately. But anyhow.
$$\sum_{k=1}^{\infty} (H_k)(x^k) = -\frac{\log(1-x)}{1-x}$$
$$\sum_{k=1}^{\infty}\left(\sum_{n=1}^{k} \frac{1}{n}\right)\left(x^k\right) = \frac{\log(1-x)}{x-1}$$
Actually,
$$\sum_{k=1}^{\infty} \frac{(H_k)(x^{k+1})}{{k+1}} = \frac{-\log^2(1-x)}{2} \implies \log^2(1-x) = (-2) \cdot \sum_{k=1}^{\infty} \frac{(H_k)(x^{k+1})}{{k+1}} $$
Since $\displaystyle \sum_{k=1}^{\infty} (H_k)(x^k) = -\frac{\log(1-x)}{1-x}$ this implies the fact that $\displaystyle \sum_{k=1}^{\infty} (H_k)((1-x)^k) = -\frac{\log(x)}{x}$
$$ (-2)\cdot \sum_{k=1}^{\infty} \frac{(H_k)(1-x)^{k+1}}{k+1} = \log^2(x)$$
$$\implies \log^2(x)\log^2(1-x) = \left((-2)\cdot \sum_{k=1}^{\infty} \frac{(H_k)(1-x)^{k+1}}{k+1}\right) \cdot \left((-2) \cdot \sum_{k=1}^{\infty} \frac{(H_k)(x^{k+1})}{{k+1}} \right)$$
$$\implies \int_{0}^{1}\log^2(x)\log^2(1-x) \,dx = \int_{0}^{1} \left((-2)\cdot \sum_{k=1}^{\infty} \frac{(H_k)(1-x)^{k+1}}{k+1}\right) \cdot \left((-2) \cdot \sum_{k=1}^{\infty} \frac{(H_k)(x^{k+1})}{{k+1}} \right) \,dx$$
$$= (4)\cdot\int_{0}^{1} \left( \sum_{k=1}^{\infty} \frac{(H_k)(1-x)^{k+1}}{k+1}\right) \cdot \left( \sum_{k=1}^{\infty} \frac{(H_k)(x^{k+1})}{{k+1}} \right) \,dx$$
$$= (4)\cdot \left( \sum_{k=1}^{\infty} \sum_{k=1}^{\infty} \int_{0}^{1} \frac{(H_k)(1-x)^{k+1}}{k+1} \cdot \frac{(H_k)(x^{k+1})}{{k+1}} \right) \,dx$$
$$= (4)\cdot ( \sum_{k=1}^{\infty} \sum_{k=1}^{\infty})\frac{(H_k)^2}{(k+1)^2} \cdot \int_{0}^{1} (1-x)^{k+1}\cdot(x)^{k+1}\,dx$$
Realize, $\displaystyle \int_{0}^{1} (1-x)^{(k+2) - 1}\cdot(x)^{(k+2) - 1} \,dx = B(k+2, k+2) = \frac{\Gamma^2(k+2)}{\Gamma(2(k+2)}$
Finally, $\displaystyle = (4)\cdot \sum_{k=1}^{\infty} \sum_{k=1}^{\infty}\frac{(H_k)^2}{(k+1)^2} \cdot \frac{\Gamma^2(k+2)}{\Gamma(2(k+2)}$
Let's see if we can simplify $\displaystyle \frac{(H_k)^2}{(k+1)^2} \cdot \frac{\Gamma^2(k+2)}{\Gamma(2(k+2)}$
$$\Gamma(k+2) = (k+1)!$$
$$\Gamma(2(k+2)) = (2k + 1)!$$
$$= \frac{(H_k)^2}{(k+1)^2} \cdot \frac{(k+1)!}{((2k+1)!}$$
Finally, $\displaystyle = (4)\cdot \sum_{k=1}^{\infty} \sum_{k=1}^{\infty}\frac{(H_k)^2}{(k+1)^2} \cdot \frac{(k+1)!}{(2k+1)!} $
I have no clue how to evaluate this sum...
Ok , you should revise it because you made a small mistake.
There shouldn't be an integral there because you already integrated, right ?
Are you sure you can do this ? I mean
$$\sum a_k \cdot \sum b_k = \sum \sum a_k b_k $$
Let us try
$$\sum_{n \geq 0}r^n = \frac{1}{1-r} $$
Is it the case that ?
$$\sum_{n \geq 0}r^n \cdot \sum_{n \geq 0}r^n = \sum_{n \geq 0} \sum_{n \geq 0}r^{2n}$$
Let us try
Question #1:
So, the answer I had for $\log(x)\log(1-x)$ is incorrect? ??
Question #2:
What are the requirements for:
Also, mmmm. Can you give me a hint? I have the parts.
I had $\log^(1-x)$ and $\log^2(x)$ written as separate sums, but I can't take the sum because the harmonic number is there.
$\displaystyle \implies \log^2(1-x) = (-2) \cdot \sum_{k=1}^{\infty} \frac{(H_k)(x^{k+1})}{{k+1}} $
$\displaystyle (-2)\cdot \sum_{k=1}^{\infty} \frac{(H_k)(1-x)^{k+1}}{k+1} = \log^2(x) $
Lets try the sum of $\log^2(1-x)$ first.
$$\sum_{k=1}^{\infty} x^{k-1} = \frac{1}{1-x}$$
$$\sum_{k=1}^{\infty} x^k = \frac{x}{1-x}$$
$$\sum_{k=1}^{\infty} \frac{x^{k+1}}{k+1} = \int \frac{x}{1-x} \,dx$$
$$(-2)\cdot\sum_{k=1}^{\infty} (H_k)\frac{x^{k+1}}{k+1} = (-2H_k)\cdot\int \frac{x}{1-x} \, dx = \log^2(1-x) = (2H_k)\cdot(x + \log(1-x))$$
$$\therefore \log^2(1-x) = (2H_k)\cdot(x + \log(1-x))$$
Now, let's work on $\log^2(x)$
$\displaystyle \implies \log^2(x) = (-2) \cdot \sum_{k=1}^{\infty} \frac{(H_k)((1-x)^{k+1})}{{k+1}} $
$$= \sum_{k=1}^{\infty} \frac{(1-x)^{k-1}}{1} = \frac{1}{x}$$
$$= \sum_{k=1}^{\infty} \frac{(1-x)^{k}}{1} = \frac{(1-x)}{x}$$
$$= \sum_{k=1}^{\infty} (-)\cdot \frac{(1-x)^{k+1}}{k+1} = \int \frac{(1-x)}{x}$$
By part-integration, $\displaystyle (-)\cdot \sum{k=1}^{\infty} \frac{(1-x)^{k+1}}{k+1} = \log(x) - x$
Recall, $\log^(x) = (-2) \cdot \sum_{k=1}^{\infty} \frac{(H_k)((1-x)^{k+1})}{{k+1}} $
So we must multiply the previous sum by $(2H_k)$ to get:
$$\log^2(x) = (-2H_k)\cdot \sum{k=1}^{\infty} \frac{(1-x)^{k+1}}{k+1} = 2H_k(\log(x) - x)$$
Finally,
$$\log^2(x)\log^2(1-x) = \left(2H_k(\log(x) - x)\right)\cdot\left((2H_k)\cdot(x + \log(1-x))\right) = (2H_k)\left(\log(x) + \log(1-x)\right)$$
$$\int_{0}^{1} \log^2(x)\log^2(1-x) \,dx = (2H_k) \int_{0}^{1} \log(x) + \log(1-x) \,dx$$
Considering that $\displaystyle \int \log(u) \,du = u(\log(u) - 1)$
$$= (2H_k)\cdot(-2) = -4(H_k)$$
I don't get it. I got
$$\int_{0}^{1} \log^2(x)\log^2(1-x) \,dx = (2H_k) \int_{0}^{1} \log(x) + \log(1-x) \,dx = -4(H_k)$$
But there is no way to compute $H_k$. What can be done?
Olok said:
Question #1:
It is correct but you should have not written it like this
$$\int^1_0(-2)(\zeta(2)-1)\,dx $$
You already integrated , right ? and you got the value to be $
\zeta(2)-1$ . Why integrating again ?
Question #2:
I must say , I don't know.
No , you can't multiply both sides by $H_k$ because the value for $k$ depends on the summation , it is like you are doing that
$$\int x \,dx = \frac{x^2}{2}+c$$
Then
$$\int x^2 \,dx = \frac{x^3}{2}+c$$
which is not correct since the $x$ cannot be inserted inside the integration. The same for $H_k$ you cannot insert it inside the summation. Also when you muliply by $x$ the outer $x$ is different than the inner $x$.
I will give the hint once we agree on the above notes.
Then
Okay.
For the first integral of $\log(x)\log(1-x)$ I agree. I just realized it was a typo. I didn't pay enough attention, sorry, but I hope you know what I meant. Anyhow,
For the other harder integral, I understand. Because (H_k) is related to $k$ so we can't simply multiply it after.
I was just thinking that:
$H_k = \int_{0}^{1} \frac{1-x^k}{1-x} \,dx$
So what we had:
First: $\log^2(1-x)$
$\displaystyle \log^2(1-x) = (-2) \cdot \sum_{k=1}^{\infty} \frac{(\int_{0}^{1} \frac{1-x^k}{1-x} \,dx)(x^{k+1})}{{k+1}} $
$\displaystyle \log^2(1-x) = (-2) \cdot \sum_{k=1}^{\infty} \frac{(-\log(1-x)\cdot\int_{0}^{1} \frac{-x^k}{1-x} \,dx)(x^{k+1})}{{k+1}} $
But the integral in the numerator does not converge.
I must say, you have given an extremely tough challenge.
Okay , here is the hint
Only expand $\log^2(1-x)$ as series. Leave $\log^2(x)$ as it is.
You will see later , why!
