Integration using partial fractions
JOhnJDC
\int(3x3-4x2-3x+2)/(x4-x2)
P(x)/Q(x)=A1/(x-r1)+A2/(x-r2)+...
if x-r occurs with multiplicity m, then A/(x-r) must be replaced by a sum of the form:
B1/(x-r)+B2/(x-r)2+...
I think this second equation is the source of my confusion.
I began by factoring the denominator:
x4-x2 = x2(x+1)(x-1)
So, according to my book, we have the following constants:
A/x + B/x2 + C/(x+1) + D/(x-1)
First question: where did the x come from in the constant A/x? Does this follow from the rule above? That is, because x2 has multiplicity 2, I get A/x and B/x2?
Next, according to my book, when you clear the fractions, you should get:
Ax(x+1)(x-1) + B(x+1)(x-1) + Cx2(x-1) + Dx2(x+1)
I don't understand this. Why isn't it Ax2(x+1)(x-1) + Bx(x+1)(x-1) + Cx3(x-1) + Dx3(x+1)?
Can someone explain? Many thanks.
you multiply everything by the original denominator to get the original fraction
try multiplying out below and it should all become clear ;)
\frac{(\frac{A}{x} + \frac{B}{x^2} + \frac{C}{x+1} + \frac{D}{x-1})(x^2(x+1)(x-1))<br /> }{x^(x+1)(x-1)<br /> }
A, B, C, and D are constants, but the expressions above aren't constant.
Yes. The denominator in factored form has an x2 factor, so the multiplicity of this factor is 2. This means that you'll need to have terms A/x and B/x2.
You have this equation, which has to be identically true (true for all values of x other than those that make any denominator 0).
\frac{3x^3 - 4x^2 - 3x + 2}{x^2(x^2 - 1)} = \frac{A}{x} + \frac{B}{x^2} + \frac{C}{x + 1} + \frac{D}{x - 1}
You can clear the fractions by multiplying both sides of this equation by x2(x2 - 1). When you multiply the terms on the right hand side above, there will be some cancellation.
That clears it up. Thanks, guys.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
