Intensity and Interference of Light Beams
An interference pattern is created by the superposition of two coherent light beams, where one beam has four times the intensity of the other. The ratio of maximum to minimum intensity in the pattern can be determined by understanding that intensity is proportional to the square of the amplitude. When two beams interfere constructively, their amplitudes add, leading to a maximum intensity that is significantly higher than the minimum intensity. The discussion highlights the relationship between intensity and interference, emphasizing that changes in beam intensity and amplitude directly affect the resulting interference pattern. Understanding these concepts is crucial for solving related physics problems effectively.
aiglosicicle
i have to do a physics assignment and i got stuck at this quesion hope u guys can help.
An interference pattern is formed on a screen by the superposition of two coherent light beams, one of which has four times the intensity of the other. What is ratio of maximum to minimum intensity in the pattern?
Something i find very hard to understand is how intensity is related to inteference. I know that when the waves interfere constructively intensity is max and vice versa, but other than that i don't understand how else intensity is related to interference... for example... like how is the intensity of the maximas affected when slit separation is increased.
Maybe your question is in the wrong place, aiglosicicle, but nevermind. IMHO the question is easier than you think. Imagine you had two beams of the same unit intensity, creating an interference pattern. Then you add another three units of intensity to the second beam.
When coherent beams interfere constructively, their amplitudes add. Intensity of a beam is proportional to the amplitude squared.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
