Interesting Infinite Powers Paradox
Ryuu
Recently, an AT&T commercial has been running on TV where a moderator asks some children about the largest number they could think of.
At the end, one kid replies “∞ times ∞”, which of course is simply ∞2.
Natually, one can instantly think of a larger number: ∞. But then, that got me to thinking about ∞.
Now, by non-standard, but logical, mathematical rules of conventions regarding reciprocal and powers notation, it can be argued that:
∞ = 1/0 = 0-1
and
-∞ = -1/0 = -0-1
This naturally leads to the formula:
= 0(0-1)
However, due to those rules governing mixtures of powers, I quickly realized that:
≠ 0(0-1)
Because
0(0-1) = 0 = 0 ! (& no, I’m not intending that to represent a factorial) :-p
Therefore, to properly notate the equation, it must go like this:
= 0-(0-1) = 0-∞ ! (& no, I’m not intending that to represent a double-factorial) :-p
Which results in the surprising conclusion:
∞ = -∞ :bugeye:
Furthermore:
1/0 = -1/0
And
1 = -1
(Of course, there is an error in the above—the negative in the exponent of 0 is the act of making the reciprocal of 0, NOT ∞.
It’s essentially the same error that folks often make when proving 1=0. Besides, even if there was no math error in my original calculation, there’s still an error in logic, as the entire exercise is merely a matter of mathematical notation, which is not the same as actual numbers.
But, ironically, it is quite interesting that the graphing of nearly any function that involves the value of ∞, there is a corresponding value to those functions that implies that ∞ does indeed equal -∞.)
Interesting.
First, we would like to define what ##\infty## actually is. Contrary to what most laymen believe, there is no unique form of infinity.
You use the relation ##\infty = \frac{1}{0}##. This relation is actually false for most definitions of ##\infty## that you use. Except for the projective real line.
In the projective real line, you add one symbol ##\infty## to ##\mathbb{R}##. And this symbol is both larger than each real number and smaller (in fact, the usual ordering relation breaks down). In this case, we can indeed define division by ##0## by ##\infty##. And interestingly enough, ##\infty = -\infty## holds in the projective real line.
So, what you described, is no more and no less that the projective real line.
http://en.wikipedia.org/wiki/Real_projective_line
And by the way, in the projective real line, it doesn't hold that ##\frac{\infty}{\infty} = 1##. So you can't go from ##\infty = - \infty## to ##1=-1##. So there is no contradiction.
Thanks, Micromass.
I've known about the concept for a long time, but I've never known its formal name.
Although I see that the first 3 lines of the Arithmatic Operations defined conflict with the first 2 lines of those undefined, if one sets a = ∞
Ryuu said:
Thanks, Micromass.
It doesn't conflict, since it says that ##a\in \mathbb{R}##. And ##\infty## is not an element of ##\mathbb{R}##.
Oh, okay. I'm not as up on some of the current heiroglyphics used nowadays.
a is a subset of the Regular Reals, but ∞ is beyond in the Regular. (Sorry, but it also seems I'm not having much fun with the Latex Reference symbols--I have to use IE at my office)
Not "subset", but "element". That is: ##a## is an element of the real numbers, but ##\infty## is not a real number.
a^2-a^2 = a^2-a^2
a(a-a) = (a+a)(a-a)
a(a-a) divided by a-a = (a+a)(a-a) divided by a-a
a=2a
1=2
... but I divided by zero
∞ = -∞ is a very natural result if you extend real numbers, as micromass mentioned. It gets even better with complex numbers.
