Interpolation of pressure from one mesh to another mesh
The discussion focuses on verifying the accuracy of pressure interpolation between two different mesh types, tetrahedral and brick elements. Key suggestions for checks include integrating pressure over the domain, interpolating random points from both meshes, and comparing results to ensure consistency. The user seeks clarification on integrating pressure and whether it involves summing pressures at each node of the elements. Additionally, a detailed method is proposed to calculate total forces on element faces before and after interpolation to assess the quality of the interpolation. Overall, the conversation emphasizes the importance of thorough validation in mesh interpolation processes.
kajalschopra
I have performed interpoaltion of applied pressure from one mesh (mesh of tetra elements) to another mesh (mesh of brick elements).
I have done the interpolation.
I want to introduce some checks if my interpoaltion is rightly done..
Please can anyone advise what could be the checks that may be acrried out?
Please help..
Kajal
Some ideas:
Integrate the pressure over the domain.
Interpolate some random points from both meshes and see if you get the same results.
Interpolate back to the original mesh to see if you get something remotely similar.
I did not get you here;
1) You say integrate pressure over the domain
Whay you mean exactly heer? does it mean that I should add the pressure on each of the nodes of each eleemnt?
Total pressure over the whole domain = Sum of pressures on every mode of every eleemnt?
Please can you eleaborate?
2) You said: Interpolate some random points from both meshes and see if you get the same results.
Is this continuation of 1)
Please he;lp
Also, I was thinking of:
1) Get the total pressure acting on every element face before interpolation (i.e on on elements of source mesh)- I can do this as I have some intrinsic functions available in the utility I'm using...
2) Get force on every element of 1 = total pressure * area of eleement face
3) Get total force summing up forces on every element face
1,2,3 were with the source mesh
Now, 4,5,6 on destination mesh
4) Get the total pressure acting on every element after interpolation (i.e on on elements of destination mesh)- agan using intrinsic functions available in the utility I'm using...
5) Get force on every element of 4 = total pressure * area of eleement face
6) Get total force summing up forces on every element face
Compare 3 and 6 which would give an ided of quality of interpolation done.
Please advise
1) Yes. Your second post explains it.
2) If the procedure you describe in the second post is expensive then you can just pick a few points in the domain and see whether the values on the two meshes agree. If you're doing the interpolation just once or you want to check your algorithm then the whole procedure is worth doing.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
