Intersection of a line and circle
To find the value of a when the product m*n is minimized at the intersection of the line x+y=2a-1 and the circle x²+y²=a²+3a-3, the first step is to square the linear equation. This leads to the relationship (x+y)² = x² + y² + 2xy, allowing for the elimination of x²+y² from the equations. By substituting this into the circle's equation, xy can be expressed as a function of a. The resulting expression simplifies the problem, making it straightforward to determine the minimum value of m*n. Ultimately, solving this will yield the required value of a.
bosonhiggs
The line x+y=2a-1 intersects the circle x2+y2=a2+3a-3 at point (m,n). When m*n reaches its minimum value, what is the value of a?
Equation One
x + y = 2a - 1
Equation Two
x2 + y 2 = a 2 + 3a - 3
Square your linear (first) equation, using the fact that (x+y)^2 = x^2 + y^2 + 2xy, at which point you can easily eliminate "x^2 + y^2" from the two equations. Now you have "xy" as a function of "a" and the rest should be easy.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
