Is intrinsic momentum a fundamental property of particles?
  • Thread starter wdlang
  • Tags
    Momentum
In summary, the conversation discusses the concept of intrinsic momentum for particles and its relationship to other intrinsic properties such as spin and parity. It is argued that while intrinsic momentum may exist, it is not physically meaningful as it cannot be measured separately from extrinsic momentum. The idea of using intrinsic momentum as a way to understand mass is also discussed.
wdlang
307
is there intrinsic momentum for some particle?
there are intrinsic angular momentum (spin) and intrinsic parity, so why not intrinsic momentum?
Even if a particle did have intrinsic momentum, it would be undetectable, since we can always choose an inertial reference frame where this equals zero. Intrinsic angular momentum is detectable since in every inertial frame we agree that the particle possesses angular momentum.
but the particle does not move at all
it is surely a surprise that a static particle has momentum
If you include the "intrinsic" momentum of a decay particle in a two-body decay, then the decay of a charged pion at rest into a muon and a neutrino qualifies. The measured muon "intrinsic" momentum in pion decay is ~29.7877±0.0014 MeV/c. See
http://prd.aps.org/abstract/PRD/v20/i11/p2692_1
Bob S
How do we measure momentum? As far as I know, there is no simple way of measuring momentum by itself; we need to measure the velocity of the particle with respect to a certain frame, and multiply that by m (or by [tex]\gamma m[/tex]). This will give you the total momentum of the particle, not just the intrinsic or extrinsic parts, since we cannot break the 4-velocity into "intrinsic" and "extrinsic" parts. Then, how do we define the intrinsic parts of the momentum?
Another way of looking at it is, the product [tex]\gamma m u[/tex] where u is the 4-velocity cannot just represent the extrinsic momentum. If it does, then, how does the intrinsic momentum manifest itself?
To be sure, an intrinsic momentum could be defined, but it isn't measurable and is not physically meaningful.
As for the cited experiment, I do not believe that the muon was at rest after it was emitted. The "at rest" specifies the pion.
Hope that helps to explain my view,
fscman
Doesn't any photon have an intrinsic linear momentum p=hk ?
No dependency on inertial frame for a photon...
The photon momentum do have a dependency on an inertial frame.
According to relativity, E=pc. We also know that E=hf, so
p=hf/c.
The thing to know is, f is dependent on an inertial frame. In fact, f is the temporal part of a 4-vector with the wave vector k being the spatial parts.
So, the momentum does depend on a inertial frame. The question is, does that count as "intrinsic" momentum?
Ah yes... Doppler.
An idea bursts into my brain. Could intrinsic momentum be the "mass"? You know, they are nearly the same from the view that E square is the sum of m square and p square. Maybe by introducing the intrinsic momentum, we could find some relations among the masses of all particles.
Momentum and intrinsic momentum are frame dependent. Intrinsic (or invariant) mass, given by
(Mc2)2 = [E2 - (pc)2]½, is frame independent.
Bob S
Bob S
As we can change the orientation of an intrinsic spin, but cannot change its magnitude, it is likely that the magnitude of "intrinsic" moemtum is invariant, but its direction could be altered. If "intrinsic" momentum possesses this property, we can extend the perception of mass. A scalar "mass" becomes a vector "intrinsic" mementum. "mass" has directions. But it is just an alternative. It might not be better than the original mass. Anyway, everything needs to be tested in the experiments.
1. What is intrinsic momentum?
Intrinsic momentum, also known as spin, is a fundamental property of subatomic particles such as electrons, protons, and neutrons. It is a type of angular momentum that is intrinsic to the particle itself, meaning it does not come from its motion through space.
2. How is intrinsic momentum different from classical momentum?
In classical mechanics, momentum is a measure of an object's mass and velocity. Intrinsic momentum, on the other hand, is a property of particles at the subatomic level and is not dependent on their mass or motion.
3. How is intrinsic momentum measured?
Intrinsic momentum is measured using a technique called electron spin resonance (ESR) or electron paramagnetic resonance (EPR). This involves placing the particle in a magnetic field and measuring the energy levels of its spin. The difference in energy levels corresponds to the intrinsic momentum of the particle.
4. What is the significance of intrinsic momentum in quantum mechanics?
Intrinsic momentum plays a crucial role in quantum mechanics, as it is one of the fundamental properties that determine the behavior of subatomic particles. It is also used to explain the phenomenon of spin-orbit coupling, which describes the interaction between a particle's spin and its motion through space.
5. Can intrinsic momentum be changed or manipulated?
No, intrinsic momentum is an inherent property of particles and cannot be changed or manipulated. However, its direction can be altered by external factors such as magnetic fields, which can cause the particle to precess around the field axis.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
