Intuition about definition of laplace transform
34 replies · 13K views
learner07
why was laplace transform developed i have googled it and found that it is something about shaping a family of exponential and vector projections etc i couldn't get it. some simply said that it was used to make a linear differential equation to algebraic equation but i couldn't understand how the variable t(time ) went in and how the 's' variable popped out. could you guys please explain me about how this laplace transform actually works? and when u say L(1)=1/s what does that actually mean ?
thanks in advance
The simplest way of understand Laplace transform is to understand Fourier transform.
Laplace transform is Fourier transform of exponential decay multiply by the given function.
This happened because we cannot Fourier transform some functions (the value goes to infinity) therefore we multiply it with an exponential decay first, then transform it,
this method is called "Laplace Transform"
Hope this help
when you say L(1)=1/s, it means that 1 in time domain is 1/s in Laplace domain.
Laplace domain is frequency domain of a function that already multiply with exponential decay.
Is it common to learn Laplace transformations without learning Fourier? We did not learn Fourier at all and my intuition is sketchy as well.
The "s" is a definition the transform of a function:
[tex]L(f(t))=f(s)=\int^{\infty}_0 e^{-st} f(t)dt[/tex]
There is no explanation on this, it is a definition.
The use of it is to solve an equation that has integration and differentiation, into a simple algebraic equation.
I don't particularly see you need to learn one in order to learn the other. They are similar in the sense of the definition and the formula of the transform, but that's about it. You can definitely learn Laplace without learning Fourier.
But again like in the other post, enroll in the ODE and PDE class, they teach you all these. I cannot emphasize how much I don't like math, but it's a necessary evil in engineering. Learn both of them.
Funny, I actually *like* math (math major) but don't like Differential equations because it seems so "engineering-y." lol
In my DE class we learned Laplace but not Fourier - going onto series now.
-Dave K
-Dave K
Series is actually very important as a lot of problems cannot be solved by conventional means and resort to numerical approx. by power series etc. Case in point, Bessel and Lagendre function are good examples of this.
Hello there
I have had the exact same thoughts as you, and I believe I have found out how you can learn more, but - I must warn you - it is not an easy way.
The best way to do it is to learn about Linear Transformations in Linear Algebra. Linear Algebra and differential equations can be coupled together quite nicely. The thing is that we want reversible Linear Transformations where the "information" is not lost when we do the transformation.
It has to do with change of basis and eigenvalues. Using these concepts its possible to get a quite intuitive idea of the laplace transform.
Fourier Transform is a simple case of decomposition, while the Laplace transform is not like that. It has a more analytical idea, that stems from the concept of a Linear Transformation.
So if you're willing. Learn Linear Algebra and then dig into Linear Transformations. Learn about how to couple Linear Algebra and differential equations, and then the Laplace transformation will be a linear transformation of a "vector" that describes the differential equation.
Yeah, series I find interesting, if sometimes elusive.
Ha ha! I don't. It's just necessary evil! Look into Bessel and Lagendre, you'll love it. It is very important for boundary condition problem in EM when using cylindrical and spherical coordinates.
hi to all i don't need math definitions.what i need is physical understanding/interpretations of what laplace transform actually is ? and how does it work every textbook gives me definitions (for those how have posted me regular definitions) @runei please tell me more about what u discussed above i mean how should i start etc etc and are their any other ways also if there please mention?
I have hoped for years to find a physical explanation or analogy for Laplace.
To me the Laplace transform is a tool that turns complex equations into simple ones.
One needn't understand impulse and momentum and fracture mechanics to use a hammer..
but he can become adept at its use through repetition.
Perhaps someday that AHA! moment will come.
I can only envy those who do understand. I accept my limitations, and appreciate those who share their deeper understanding.
old jim
Perhaps this is a case of.. "Young man, in mathematics you don't understand things. You just get used to them..." (John Von Neumann)
Read my last post, it is a definition. It is like I am making up my transform called Alan transform and is defined as
A(f(t))= f(t)+1
It is absolutely useless, BUT it's a transform!:smile: Difference is my transform don't worry anything and Laplace transform works!
Their might not be any rhyme and reason at all. There are a lot of things like this in science and math. The higher level you go, the more you encounter, try Fourier transform, Bessel, Legendre, try to make sense where it came from. It a big miss conception that science comes from theory, then proved by observation. A lot of them started from observation, then make up the theory and math. Some by intuition. Do you know how they discover the benzene ring in chemistry? The guy had a dream of a snake biting it's own tail and it goes around and around! Then he went on and proved that was true! That's part of the reason I quit chemistry after I got the degree, I thought everything has a reason and from theory to practice...I was wrong and I want to have nothing to do with it.
You are in the wrong section here, go to "Differential Equation" in the math section here and ask. This is math.
I can try and tell you how I got my kind of intuition first.
  1. Learn Linear Algebra. Look at Khan Academy, and I can recommend the book "Linear Algebra and it's Applications 4th" by David C. Lay.
  2. Pay special attention to the Linear Transformations places and do some of the problems
  3. Learn that FUNCTIONS ARE VECTORS! This is an important part
  4. Learn how to couple Linear Algebra and Differential Equations
  5. Learn how the Laplace Transform is a Linear transformation
I can also recommend the following websites where they talk about it:
1. http://www.quora.com/Intuitively-speaking-what-does-a-Laplace-transformation-represent (the first answer is a guy explaining exactly what I am talking about, but if you haven't learned Linear Algebra, it is hard to understand)
2. http://mathoverflow.net/questions/2809/intuition-for-integral-transforms (look at the answer from John D. Cook - answer number 3 i believe. He gives a possible geometric interpretation)
3. (his introduction has another good interpretation)
The thing is - There can be MANY interpretations of the transforms. But learning a lot of them will give you more and more of the puzzle. At some point. You will get it.
l7,
Why were logarithms developed? So one could multiply and divide by adding and subtracting.
Why is the Laplace transformed? So one could manipulate and solve differential equations by algebraic means without calculus.
Did you ever try to integrate a simple function using the Laplace integral to observe how the "e" term disappears when the upper limit "t" goes to infinity. And how it becomes one when the lower limit is zero?
There are a hundred thousand textbooks that do that. Why should any of us duplicate that effort over again? 1/s is the Laplace transform the the unit step function. That is explained many times in textbooks also.
Ratch
P.S. In English, sentence beginnings are capitalized. It makes them easier to read that way.
Instead of getting tied in knots about how the transform works, it might be better to learn what the s-plane represents - for example what the locations of poles and zeros mean for the dynamic behaviour of a system.
Laplace Transform is one of the simpler ones that has a calculus representation already. In real world, quite a bit of result can only be represented by numerical analysis which is some form of power series. Try to make sense out of that! People might be plotting out an input to output response and literally doing a curve fitting to develop an equation for it.
Like Ratch gave, log is one of those, why do log? From my understanding, one reason is human ears response logarithmic to sound power, there must be a lot of other reason, but that's good enough for me!
I remember the first lecture from the instructor of my Physical Chemistry that really stuck in my mind: Invention or discovery of a theory start with an idea or postulation. Then confirm or disprove using observation and experiment. If the postulation holds after scrutiny, then it is consider true and become a law. At the same time, mathematical formulas are developed to full fill the observation. Sometimes the postulation is proven by mathematical derivation. It is not the other way around that you have a theory or equation first.
If you get stuck with Laplace, try quantum physics! I quit chemistry after I score the first in the class of the Physical chemistry and I was like 15 points above the second student. I worked in the chemistry dept. at the time and it's like the professor came to the stockroom window everyday answering my questions. Finally he said to me " Alan, you are not going to understand this, keep at it, when you get your PHD, you'll start to get the feel of it". This might not be the exact word to word, but it's very close. I quite chemistry after that, I just finished my degree and never even look for a job in that field. Between the snake biting it's tail and this, I quit. I did not know at the time it's like this in all science. Now I can really appreciate his first lecture and what he said.
Functions are vectors and therefore they can be represented in any coordinate system you want. Just like when you apply a transformation on a spatial vector to transform from xyz coordinates to polar, the Laplace transforms the function by projecting it onto a different space.
I tried to think of an analogy that would make this idea a little more tangible and I came up with a technical drawing. A technical drawing uses three projections to make a 3D object seem simpler to the eye. You could choose to represent a 3D object with an animated model that rotates in time, instead. If you did that, it would be very easy for your eye to interpret the picture and get a good impression of the object's shape, but measuring precise lengths and angles would be very hard, and you would have to have some kind of magic paper to display it. It becomes simpler to represent it with still images in three different locations on a piece of paper. In these two different representations, the viewing angle is either a function of time or location, and the relative length of a line may or may not depend on relative distance. We transform the coordinates to a equivalent but more easily understood system. We also choose to align the axis of the drawing in a way that is convenient for design and construction, the same object could be represented with a drawing from three other arbitrarily chosen orthoganal directions but that would be confusing to your eye.
I think this is similar to the situation of the laplace transform because its useful for transforming time-varying functions into inanimate pictures in which time dependence is represented by spatial coordinates. In S-space, periodicity becomes a length along one axis, and the slope of exponential decay becomes a length along the other axis, any functions of S-space that are multiplied together represents the convolution of their time-varying counterparts (which is why its useful for filter analysis), and phase angles look like... angles. Like in the technical drawing example, drawing things in different locations now represents something totally different and makes it easier to express certain ideas.
S-space is a nice place to work if your job is doing a lot of convolution, differential equations, and phase analysis. The laplace transform is like the train that you take to commute from regular space where you live to S-space where you work.
Once you've mastered the Laplace Transform, try the fractional Fourier Transform... I still don't get that one
learner07 said:
i don't need math definitions. what i need is physical understanding/interpretations of what laplace transform actually is?
A(f(t))= f(t)+1
there is a rhyme and reason. but the story or poem is long, not quite epic, but it's long. maybe as long as a semester long class in Linear System Theory (now they call it Signals and Systems or differential equations.
so 07, you understand what the concept of a "transform" is, right? maybe a good example is the logarithm. this transform turns a multiplication problem into an addition problem (this is because when you multiply to exponentials with the same base, you add their exponents). it also will turn a power problem into a multiplication problem. normally the latter (the transformed problem) is easier to deal with.
the Laplace Transform will turn a certain class of linear differential equations into polynomials. supposedly the latter is easier to deal with.
the real thing about Laplace is that it's a generalization of the Fourier Transform which itself is a generalization of Fourier series.
Fourier conceptuallizes functions or signals as being a sum of sinusoids, but because of Euler's formula, a sinusoidal function is actually an exponential function (with complex or imaginary exponent). and Laplace conceptualizes functions or signals as being a sum of exponential functions.
why are exponential (or sinusoidal) functions so important that you would want to use them as the basis for creating general functions? it's because exponential functions are eigenfunctions to these operations that we call Linear, Time-Invariant systems. LTI systems are very important and fundamental. if a sinusoid or an exponential function goes into an LTI system, what comes out is a sinusoid of the same frequency, or if an exponential goes into an LTI system, what comes out is the same exponential except it will be scaled by some constant.
so that is why we want to understand a signal or a function in terms of these exponential building block, because LTI systems will deal with each block simply instead of dealing with a signal as a whole.
I am no math expert, I just learn math to survive electronics. I just went back and look at 5 books I used to study ODE and PDE:
1) Introduction to Laplace Transform by W.D DAY
2) PDE with Fourier Series and BVP by Nakhle H. Asmar.
3) Differential Eq. by Zill and Cullen.
4) Elementary Applied PDE by Richard Haberman.
5) Elementary Differential Eq. and BVP by William E. Boyce.
NONE present where this equation came by. Yes, they all talked about linear transformation and all, talked about how they justify the usefulness. It is understand here that the use of LT to transform a differential equation into a much simpler form, that's the application side of it. The advantage is very obvious. But nothing on how the Laplace transform equation came by.
In fact on Page 479 of Asmar, the first page on the chapter of LT, the first line is:
"Should I refuse a good dinner simply because I do not understand the process of digestion?"
By OLIVER HEAVISIDE.
[Criticized for using formal mathematical manipulations, without understanding how they worked.]
That's what I was talking about the dream of a snake biting it's own tail for discovering the most important organic compound of the Benzene Ring. And Eisenstein had relativity in mind for years before he could come out with observation and math to prove it. Of cause, now they have books on the benzene rings, why it is a ring, relativity and all, they can characterize everything and all the theory, but that comes later, that's the interpretation of the original equation! BUT where they originally come from can be very funky! That, there may be no explanation other than just stroke of genius and creativity.
The books do talk about the particular usefulness for solving second order ODE with constant coef as the solution is in exponential form and is particular suitable for using LT. Maybe I have not gone deep enough, I have not seen using Eigenfunction in LT.
My professor said that the Laplace transform transforms an ODE into an algebraic expression. Then on a test he gave us the following: https://www.physicsforums.com/showthread.php?t=654318. I got that the Laplace transform changed a second order ODE into a first order ODE and didn't proceed further since in the lecture he said that "we should get an algebraic expression" so I thought I had made some mistake. Now at home I realized that I should have proceeded further. Sigh.
well, yungman, it's after midnight now, so i am a little tired. maybe tomorrow i can go through the step-by-step (nowadays this should be in a Signals and Systems course) that starts with
1. Linear Time-Invariant systems (LTI), just the definitions.
2. show how the convolution summation (for discrete LTI) or convolution integral (continuous-time LTI) are derived directly from the definitions of LTI.
3. show how exponentials are eigenfunctions of LTI systems ([itex]e^{\alpha t}[/itex] goes in -> [itex]A e^{\alpha t}[/itex] comes out)
4. with Euler, show how sinusoids are also a sort of eigenfunction of LTI systems ([itex]e^{j \omega t}[/itex] goes in -> [itex]A e^{j \omega t}[/itex] comes out)
5. then generalize a little more from sinusoidal to periodic input (Fourier series). note that in deriving the Fourier coefficients, this is where the integral that ultimately becomes the Laplace Transform will first emerge.
6. then generalize a little more and let the period go out to infinity, so the periodic input becomes non-periodic. then look at that integral for the Fourier coefficients. it becomes the Fourier Integral.
7. that Fourier Integral looks just like the double-sided Laplace Integral except the Fourier has [itex]j \omega[/itex] in it where as, if you generalize further, the double-sided Laplace Integral has [itex]s = \sigma + j \omega[/itex] replacing [itex]j \omega[/itex].
so biologists and physiologists, if they drill down a little, do understand, for the most part, how digestion works. they don't simply say "it works, let's eat."
I don't think we are talking about the same thing. I guess another way of looking at this is: Is there a derivation of
[tex]L(f(t))=\int_0^{\infty} e^{-st} f(t) dt[/tex]
If this is derived from the existing theory, then I hope at least one of my 5 books would have mentioned where the equation comes from. In another word, the history of Laplace transform. We all know the application and the indefinite integral, the kernel etc. I am not particular familiar with Laplace transform, all I can based on is the 5 books I have. When you talk about LTI, is Laplace transform derive base on that? If yes, that's good enough for me, you prove your point. If Laplace transform fit into the LTI, that does not prove anything.
You don't need to repeat all the theory to characterize Laplace transform, just the original history of Laplace transform, I think that's what the OP was asking since he is not interested in the definition and all. I assume he know enough about the application of it.
That's the application side, that it transform
[tex]L(y')=-y_0+sL(y) \;\hbox { and } \; L(y'')= -y_0' -sy_0 + s^2L(y)[/tex]
Or
[tex]L( \cos(at))= \frac s {s^2+a^2}[/tex]
This is the history I found:
http://en.wikipedia.org/wiki/Laplace_transform
The Laplace transform is named after mathematician and astronomer Pierre-Simon Laplace, who used a similar transform (now called z transform) in his work on probability theory. The current widespread use of the transform came about soon after World War II although it had been used in the 19th century by Abel, Lerch, Heaviside and Bromwich. The older history of similar transforms is as follows. From 1744, Leonhard Euler investigated integrals of the form
[tex]z = \int X(x) e^{ax} dx \hbox { and } z = \int X(x) x^A dx[/tex]
as solutions of differential equations but did not pursue the matter very far.[2] Joseph Louis Lagrange was an admirer of Euler and, in his work on integrating probability density functions, investigated expressions of the form
[tex]\int X(x) e^{- a x } a^x dx[/tex]
which some modern historians have interpreted within modern Laplace transform theory.[3][4][clarification needed]
These types of integrals seem first to have attracted Laplace's attention in 1782 where he was following in the spirit of Euler in using the integrals themselves as solutions of equations.[5] However, in 1785, Laplace took the critical step forward when, rather than just looking for a solution in the form of an integral, he started to apply the transforms in the sense that was later to become popular. He used an integral of the form:
[tex]\int x^s \phi (x) dx[/tex]
akin to a Mellin transform, to transform the whole of a difference equation, in order to look for solutions of the transformed equation. He then went on to apply the Laplace transform in the same way and started to derive some of its properties, beginning to appreciate its potential power.[6]
Laplace also recognised that Joseph Fourier's method of Fourier series for solving the diffusion equation could only apply to a limited region of space as the solutions were periodic. In 1809, Laplace applied his transform to find solutions that diffused indefinitely in space.[7]
It is a continuation of Euler and Lagrange's development. Now the question is what's is the history of Euler's.
Fantastic thread. I want to take some time to digest this during break. My encounter with laplace was unpleasant.
indeed a neat thread. I am grateful to the pointers to early mathematicians...
My experience with Laplace transforms was in automatic controls, which would be impossible without them.
i read someplace that the math of feedback systems was developed by Descarte and shelved. Of course it was shelved, for there was no automation at the time.
During WW2 the Germans revived Descarte's old math for their rocketry programs and their textbooks were among the war prizes we brought back. Along with the rocket scientists to explain them.
I passed my controls courses by using Laplace as a tool whose workings i did not comprehend.
I'd suggest that repetition might be your quickest way to conquer this. At least it'll make you familiar with the patterns, and for me that usually leads to insight. But I never mastered Laplace's transform.
old jim
old jim
Being able to understand the theory and being able to design are not necessary related. There are people that are very good in theory and there are people that can design! To me, there is an artistic component in electronic design, I made use quite a bit of my experience as a musician when I was young.
I know people that are very strong in theory but cannot design squad! As an engineer, it's the result that is important, people hire one that can design good electronics using fortune telling than someone that can talk theory and can't produce. AND it is more irritating to have someone that can't get the job done and then argue with you in theory why it can't be done! Of cause, best will be good in both, but I'll take someone that can design any time of the day.
I am not good with Laplace transform and Fourier transform. I study these for signal and system, modulation. But after I studied these, then I found out that I still need statistic and probability to really understand the books. I kind of drop it all together and choose RF, EM instead, I rather get into transmission line, RF amplifier and antenna design. Those are totally different animal all together. I spend the most time on that instead. I still use Bode Plot for closed loop feedback designs! Simple, but works for me.
I found the first lecture and what the professor said to me described in post #19 is so important, that really open my eyes in the field of science. There are a lot more "guessing", "opinion", "eagle" and "politics" in science than people realize. There are a lot of theories, math come after the fact...It's like Monday morning quarterbacking, people analyzed to death why the team lost the game, what is the reason and all. Or even why a team won a game.
