Intuition for General/Special Relativity theorems without experiments
solr
I am not a mathematician, so I always used to wonder about following.
"I never heard Einstein conducting any experiments, But how he predicted the physics properties the way it is explained in Relativity Theorems. These are some of the breakthroughs of that time, But without the intuition from the experiments how Relativity Theorems are developed? "
At the same time, How it required experiments to develop the theories related to invention of the transistor, Like a new branch of Quantum Psychics to account for the odds they observed.
Also,
How theoretical physics related to practical physics, how they evolve ?
Can anyone point me to the resources to develop this mathematical intuition.
I could be asking a totally stupid question here.
There were many experiments involved in Einstein's theories.
In special relativity, he used the fact that you can drink coffee in an aeroplane just the same as you were stationary on the ground. He assumed this is true for all speeds. This is the "Principle of Relativity".
In general relativity, he used the fact that different materials of different masses always fall to the ground at the same time. This is worked into his "Principle of Equivalence"
So Einstein used old experiments that everyone can do, and built his theories by assuming that these old experimental facts could be generalized to very high speeds, or to very strong gravitational fields.
Apart from the Principle of Relativity, Einstein also used Maxwell's equations, which are based on experiments by Ampere, Faraday etc.
Thanks for your reply, I am checking along your lines.
Can you give some resources, so it is quite clear on how developed those theorems.
AFAIK, The ampere and faraday experiments are quite a lot simple compared to these theorems.
The question still didn't quite answered.
Especially about the theoretical and practical, if there is such distinction in the first place.
As long as Einstein read the results of experiments performed by other people, he didn't necessarily have to do them himself. This is the theorist / experimentalist split.
I don't think Einstein focused on reading experimental results from all reports (I'm not a historian), but he was aware enough of them to abandon theories that did not agree with experiment.
If a theorist gets totally cut off from experiment, they'll become unprodctive in developing theories that will be ignored because they are known to be wrong because they don't agree with measurments.
I am reading a paper by Dirac from 1931, in which he showed that it is necessary for there to be magnetic monopoles if electric charge is quantized.
It requires some mathematical facility, but he is very good at explaining his thoughts, and the whole point rests on a thought experiment.
He also explains a lot of why modern physics gets so far into abstract math.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
