Inverse of Automorphism is an Automorphism
  • Thread starter Thread starter BrianMath
    Inverse
BrianMath
Verify that the inverse of an automorphism is an automorphism.
Let f:G\to G be an automorphism. Then, f(xy)=f(x)f(y) \forall x,y\in G.
Then, we define the inverse f^{-1}:G\to G by f^{-1}(f(x)) = f(f^{-1}(x)) = x \;\;\forall x\in G. We get f^{-1}(f(x)f(y))=f^{-1}(f(xy))=xy=f^{-1}(f(x))f^{-1}(f(y)). Since f^{-1}(f(x)f(y))=f^{-1}(f(x))f^{-1}(f(y)), f^{-1} is an automorphism.
I was watching http://www.extension.harvard.edu/openlearning/math222/" , and this came up as an exercise in lecture 3. I was wondering if I did this problem correctly.
Seems good! :smile:
As an exercise however, it would be benificial if you indicated where exactly you use injectivity and surjectivity...
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
