Invertible linear transformation
yifli
State why it is that if V is finite-dimensional, and if S and T in HomV satisfy S\circ T = I, then T is invertible and S=T^-1
2. The attempt at a solution
Isn't this obvious? I don't understand why any elaboration is necessary
Hi yifli! :smile:
No, this isn't obvious. T invertible means
S\circ T=1~\text{and}~T\circ S=1.
Now you only have that S\circ T=1. Somehow, you need to show T\circ S=1.
(Hint: use determinants)
You don't need to use determinants (or even matrices), and in fact doing so might introduce circular logic depending on what theorems you use.
Instead, answer this:
S\circ T = I
implies that T is _____ and S is _____
(Fill in the blanks with either injective or surjective as appropriate.)
Then you'll need to use the finite dimensionality of V to draw a conclusion.
S\circ T = I
implies T is injective and S is surjective
since V is finite dimensional, T is an isomorphism,so S = T^-1
micromass said:
Hi yifli! :smile:
Can you give me an example that shows T is not invertible if only ST=I is given?
thanks
thanks
It has to be an infinite-dimensional example, as you just showed.
Let V be the vector space consisting of infinite sequences of the form
(a_1, a_2, a_3, \ldots)
where the a_i are real numbers. (Or complex. It doesn't matter.)
Addition and scalar multiplication are defined pointwise in the obvious way.
Let T be the operator that shifts the sequence right by one step:
T(a_1, a_2, a_3, \ldots) = (0, a_1, a_2, \ldots)
And let S be the operator that shifts the sequence left by one step:
S(a_1, a_2, a_3, \ldots) = (a_2, a_3, a_4, \ldots)
You can verify that these are linear operators, and that
S \circ T = I
but
T \circ S \neq I
T can be "undone" but S cannot.
thanks
With other things than vector spaces you mean?
Well, take T:{1}-> {1,2} with T(1)=1 and take S:{1,2}->{1} with S(1)=1 and S(2)=1.
