Chemistry Investigating dsp2 & sp3 Configurations in Ni2+ Complexes
The discussion focuses on the hybridization and geometry of nickel complexes, specifically Ni2+ in [Ni(CN)4]2- and [Ni(NH3)4]2+. It clarifies that the t2g and eg labels are applicable only to octahedral geometries, suggesting that discussions typically center around octahedral complexes. The existence of [Ni(NH3)4]2+ is questioned, with references to its rarity and the predominance of octahedral complexes in literature. The conversation also touches on the energy levels in tetrahedral geometries, noting that they differ from octahedral configurations. Overall, the participants emphasize the importance of understanding crystal field theory (CFT) in relation to these complexes.
Gourab_chill
Does Ni2+ have different t2g eg configuration for wfl and sfl?
no equations
I was expecting Ni2+ to be present also in the answer as it can give dsp2 and sp3 configuration.
[Ni(CN)4]2- and [Ni(NH3)4]2+ have dsp2 and sp3 respectively, right?
Two things. First, the labels t2g and eg only apply to octahedral geometries. Are your nickel compounds octahedral?
Second, does [Ni(NH3)4]2+ exist on its own? I'm familiar with the hexaammine and the mixed ammine with other ligands (all octahedral). I can't say I've ever encountered a tetraammine nickel compound.
Well so it means we are only considering octahedral compounds here? Then it is always sp3d2 for Ni2+ compounds.
Then what are the energy levels involved in tetrahedral geometry, if they are not t2g and eg?
I did search for [Ni(NH3)4]2+ and found that people asking questions on whether it is para or diamagnetic, it's hybridization etc. Are you sure it doesn't exist?
I did the same search and mostly found references to homework problems (not actual scientific papers). I did find one paper on a tetraammine nickel compound with a complicated molybdate counterion. The IR spectrum was interpreted as having two short and two long Ni-N bonds. I suspect most tetraammine nickel (II) compounds are probably hexacoordinate (octahedral/JT distorted) in reality.
Also, yes generally these discussions only happen in the context of octahedral complexes, since the ligand field splitting in tetrahedral complexes is always too small to affect spin states.
I should clarify: octahedral compounds will have different electronic structures from tetrahedral and square planar compounds. So a square planar nickel compound very well may have a different spin configuration from an octahedral compound. But for the purposes of this particular question, it’s pretty clear (at least to me) that they were asking about octahedral complexes alone.
Also, generally for tetrahedral complexes, t2 and e are more accurate labels reflecting the group symmetry (there is no gerade symmetry in the complex). This is moot for nickel square planar complexes, which do not have the 3-2/2-3 d-orbital splitting characteristic of octahedral or tetrahedral geometries.
Likes Gourab_chill and jim mcnamara
Yes, I missed out that point earlier. I need to strengthen my concepts on CFT :)
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
