Investigating Properties of Inverse Functions
The discussion centers around the properties of the function g(x) = 4(x-3)^2 + 1 and its inverse. The user successfully completed parts a-d but struggles with part e, which questions whether the inverse is a function given a specific domain. The conclusion is that the inverse is not a function because it produces two different y-values for the same x-value (specifically at x=5). The algebraic justification involves evaluating the inverse function at x=5, yielding two results, which confirms the violation of the function definition. The conversation highlights the importance of understanding domain restrictions for inverse functions.
msimard8
Ok here is teh question, there is parts a-e, i have a-d answered correctly, but am having trouble on e.
Q: A function g is g(x)=4(x-3)^2 + 1
a) Graph g and the inverse of g. (Already completed)
b) At what points do g and the inverse of g intersect. (completed)
c) Determine an equation that defines the inverse of g.
the answer is y=3 +/- (root of (x-1/4) )
d) State restrictions on the domain or range of g so that its inverse is a function.
i got x is greater or equal to 3 and x is less than or equal to 3
then finally
e) Suppose teh domain of g is {x|2 < or equal to x < or equal to 5, XER}
Would the inverse be a function? Justify your answer.
Ok. The answers say the inverse is not a function because the
inverse of g (5) = 2 and
inverse of g (5) =4
i guess that makes sense because there is two y coordinates for that x. My question how do you algabraically solve that. Help would be appreciated. Thanks
then finally
inverse of g (5) =4
Simple. Hopefully your inverse function was supposed to be:
y=3 \pm \sqrt{\frac{x-1}{4}}
So using the + sign: y(5) = 3 + 1 = 4.
Using the - sign: y(5) = 3 -1 = 2.
Since we may use either sign, that means that y(5) is double valued, which violates the definition of a function.
-Dan
thanks
Thanks a lot Dan.
One question. Why are you using f(5). Why did you chose the number 5. Is it because it is the highest possible x coordinate.
Thanks
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
