How Can You Determine the Percentage of Iron(ii) and Iron(iii) in a Mixture?
  • Thread starter Thread starter RE-com
    Iron
To determine the percentage of Iron(II) and Iron(III) in a mixture, a volumetric analysis method is proposed, utilizing the redox reactions between the two iron ions. The solution contains between 1.1g and 1.3g of iron ions, with each ion present at least 30% by mass. A suggested approach involves converting Iron(III) to Iron(II) using a reducing agent and then titrating the Iron(II) with potassium permanganate. The difference in measurements before and after the conversion will indicate the amounts of each iron ion present. Further justification of concentrations and procedures is necessary for a complete analysis.
RE-com
You must devise a volumetric procedure to determine the percentage or Iron(ii) and Iron (iii) in a mixture containing both.
You are provided with 200cm^{}3 of a solution containing between 1.1g and 1.3g of iron ions as a mixture of Fe^{}2+ and Fe^{}3+(aq). You may assume that each of the two ions is present to at least 30% by mass. You have the normal apparatus required for volumteric analysis but a balance is not available.
The max and min. mass range = 1.1x0.3=0.33g min. and 1.3x0.7=0.91g
Try to put in a little more effort in your attempt at a solution. Do you know of any tests that are specific for either iron (II) or iron (III)? Know of any way to convert one quantitatively into the other?
I do have some ideas I've already jotted down but whether or not they will work I have no idea:
Fe^{}2+ - e \rightarrow Fe^{}3+
Using MnO_{}4^{}-+8H^{}+ + 5e \rightarrowMn^{}2++4H_{}2O
Work that out ?
Then (just tell me to stop if this is completely wrong):
Fe^{}3++ e \rightarrowFe^{}2+
Then use a reducing agent so :
2I^{}- - 2e\rightarrow I_{}2
Using S_{}2O_{}3^{}2- for getting rid of the excess Iodide that would be left
so bascally measure the Fe^{}2+ with the MnO_{}4^{}- then convert Fe^{}3+ to Fe^{}2+
Measure it again, then difference is the amount of Fe^{}3+
but it says justify concentrations etc, I don't have a clue where to start on that front
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
