B Irrational inequalities √f(x)>g(x) and √f(x)>g(x)
Danijel
So, I know that the inequality √f(x)<g(x) is equivalent to f(x)≥0 ∧ g(x)> 0 ∧ f(x)<(g(x))^2. However, why does g(x) have to be greater and not greater or equal to zero? Is it because for some x, f(x) = g(x)=0, and then > wouldn't hold? Doesn't f(x)<(g(x))^2 make sure that f(x) will not be equal to g(x)?
If that is so, then how is now √f(x) < g(x) equivalent to f(x)≥0 ∧ g(x)≥0 ∧ f(x)>(g(x))^2, where g(x) can now be equal to zero?
Also, what happens to the conditions when √f(x)≤g(x) or √f(x)≥g(x)?
Mathematics news on Phys.org
There are some quantifiers missing, like "for all real x".
It does. That doesn't make the requirement g(x)> 0 wrong, it just makes it unnecessary.
It cannot be equal to zero.
What do you think?
mfb said:
There are some quantifiers missing, like "for all real x".It does. That doesn't make the requirement g(x)> 0 wrong, it just makes it unnecessary.It cannot be equal to zero.What do you think?
Does that mean that √f(x) < g(x) is not equivalent to f(x)≥0 ∧ g(x)≥0 ∧ f(x)>(g(x))^2, but to f(x)≥0 ∧ g(x)>0 ∧ f(x)>(g(x))^2, or both, since f(x)>(g(x))^2 implies that g(x) cannot be equal to zero, so it is the same thing? I don't understand then why would anybody write g>0 for √f(x)<g(x) and and g≥0 for √f(x)>g(x), if g≥0 or g>0 can be written in both. It is confusing.
For your question, I think that everything stays the same, except the part f(x)≤(g(x))^2, where < is now ≤.
Thank you for your reply.
Also, if √f(x)> g(x), and if f(x)≥0 and g(x)>0 and f(x) > (g(x))^2 then f(x) can = 0 , but 0 is not greater than any g(x) > 0, so f(x) should be strictly greater than zero.
I meant that √f(x) > g(x) is equivalent to f(x)≥0 ∧ g(x)≥0 ∧ f(x)>(g(x))^2. Sorry.
The two are the same thing, right. The second one makes it easier to see that g(x) cannot be zero.
Careful, this is a completely different expression.
You used a wrong conclusion to derive another wrong conclusion. If you have √f(x)>g(x), why should g(x) be larger than 0? What is wrong with negative g(x)?
mfb said:
The two are the same thing, right. The second one makes it easier to see that g(x) cannot be zero.Careful, this is a completely different expression.You used a wrong conclusion to derive another wrong conclusion. If you have √f(x)>g(x), why should g(x) be larger than 0? What is wrong with negative g(x)?
I used wrong to derive wrong, intending to show that the former had to be wrong. That is, I tried to find a contradiction.
There is nothing wrong, sorry. I overlooked it.
