Irreducible polynomial, cyclic group
mathsss2
Describe the field F=\frac{\mathbb{F}_3[x]}{(p(x))} [p(x) is an irreducible polynomial in \mathbb{F}_3[x]]. Find an element of F that generates the cyclic group F^* and show that your element works.
[p(x)=x^2+1 is irreducible in \mathbb{F}_3[x] if that helps]
I've already given you a warning about posting your homework questions without showing your attempts to work on the problem. Continuing to do so will not be tolerated.
Not to mention this should be in the Abstract Algebra forum.
Write the elements of F explicitly (in terms of, say, t, where t2 + 1 = 0). Find one that has order 8.
I asked online questions about Proposition 2.1.1: The answer I got is the following: I have some questions about the answer I got. When the person answering says: ##1.## Is the map ##\mathfrak{q}\mapsto \mathfrak{q} A _\mathfrak{p}## from ##A\setminus \mathfrak{p}\to A_\mathfrak{p}##? But I don't understand what the author meant for the rest of the sentence in mathematical notation: ##2.## In the next statement where the author says: How is ##A\to...
The following are taken from the two sources, 1) from this online page and the book An Introduction to Module Theory by: Ibrahim Assem, Flavio U. Coelho. In the Abelian Categories chapter in the module theory text on page 157, right after presenting IV.2.21 Definition, the authors states "Image and coimage may or may not exist, but if they do, then they are unique up to isomorphism (because so are kernels and cokernels). Also in the reference url page above, the authors present two...
##\textbf{Exercise 10}:## I came across the following solution online: Questions: 1. When the author states in "that ring (not sure if he is referring to ##R## or ##R/\mathfrak{p}##, but I am guessing the later) ##x_n x_{n+1}=0## for all odd $n$ and ##x_{n+1}## is invertible, so that ##x_n=0##" 2. How does ##x_nx_{n+1}=0## implies that ##x_{n+1}## is invertible and ##x_n=0##. I mean if the quotient ring ##R/\mathfrak{p}## is an integral domain, and ##x_{n+1}## is invertible then...
