swraman said:
Thanks. I am not really looking for a proof, Ill take your word for it :) I do have Nagel/Staff's Diffeq book lying around, Ill look it up in that if I ever need to.
So the Transfer Function is the Laplace Transform of the system. So to find the Transfer function, you'd characterize the function in the time domain then Laplace Transform it?
You could do that. Most often, you have some differential equation, and then you take the Laplace transform of that (why? differentiation is a 1/s factor, and integration is an s multiplier--reduces your differential equation into an algebraic one). But coming up with the differential equation (with, say, an RLC circuit) is, in fact, characterizing the system in time.
swraman said:
And Taking the Fourier transfer of the function would be the same as taking the Laplace function, then substituting...what? (you mentioned subbing s=iw?)
The Fourier transform shows the frequency content, and takes a function from the time domain to the frequency domain. Similarly, taking the laplace transform maps a function from the time domain to what domain? that is, what physical quantity does the Laplace transform reveal?
Yes, but as I mention, a Fourier transform is just a special case of the Laplace transform. In a Laplace transform, you use complex frequencies s=\sigma+j*\omega, while in the Fourier transform, \sigma is 0 (purely imaginary--i.e. a sine, or cosine, or some such, the basis set of the Fourier transform!)
Actually, given some of your questions, I may be getting ahead of myself... If you haven't taken your EE continuous-time Laplace / Fourier transforms class (often goes by the name Continuous Time Signals, or Fourier Transforms, or some such), or an introductory controls class, then that's where you'll be learning this more in detail. The Laplace transform does map to a frequency transform--just a complex one (a 'real' frequency means that a signal has a non-periodic portion).
Unfortunately, it's been a number of years since I've really any of this in great detail, so I may have to refer you back to the textbook, or one on Linear Systems (B. P. Lathi, but hopefully something a little better and less pricey). In the meantime, I'll point you to the Wiki regarding the relationship between the Laplace and Fourier transforms:
http://en.wikipedia.org/wiki/Laplace_transform#Fourier_transform
EDIT: TeX is still broken--look in the Wikipedia page above.
