Is an isometry always a statement about the principle of covariance?
quasar_4
Can someone help me out with this idea?
Let's say we have a diffeomorphism. We know that under certain circumstances (invariance of the metric) this diffeomorphism is an isometry. Here is the part I'm not sure about. Is an isometry always just a statement about the principle of covariance? I.e., under an isometry, do the laws of physics always look identical in any coordinate system? Or is the isometry a necessary, but not sufficient condition, and there are more restrictions on the diffeomorphism?
General covariance is just the idea that the laws of physics are tensor equations. Isometries don't have anything to do with it.
Special covariance in SR is the fact that if you consider the components of a tensor equation in an inertial frame and replace the symbols g_{\mu\nu} that represent the components of the metric with the corresponding numbers, the result will look the same no matter what inertial frame you're using.
The connection to isometries is that the isometry group of Minkowski space is the Poincaré group. So there's exactly one isometry for each inertial frame and vice versa.
Oh, that's right... I forgot about that.
I must be thinking of something else that was special about isometries... but... if they are only interesting in that they give us the Poincare group, then why bother to go looking for them? Is there any relation to symmetry and conservation laws, or are those completely different?
General covariance is very general (to the point of being trivial), and applies to Newtonian mechanics, Maxwell's equations, and General Relativity. It just means you can make the dynamical equations look the same under all coordinate transformations.
A solution of Einstein's equations consists of a manifold, a metric and a stress-energy tensor. You can create another solution by using a diffeomorphism to move the points, metric and stress-energy tensor to another manifold, ie. with regard to the metric, you use the diffeomorphism to create an isometry. Even in Newtonian physics the metric is a geometric coordinate-independent object that defines a physical situation, so it's no surprise that isometric situations should be physically the same.
Some people make a big deal about having to fix a gauge for unique evolution ("hole argument"), but that is apparently true for any differential equation that arises from geometry (Jaramillo et al, From Geometry to Numerics http://arxiv.org/abs/0712.2332)
The difference between Newtonian and Einstein gravity is not general covariance, but "no prior geometry", ie. metric and matter must be determined together (MTW; Giulini, Some remarks on the notions of general covariance and background independence http://arxiv.org/abs/gr-qc/0603087)
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
