Is angular frequency absolute?
Angular frequency in classical mechanics can vary based on the reference frame used. When two objects rotate around their common center of mass, their angular frequency remains consistent across different inertial frames. However, if rotations are considered around the origin of a coordinate system, the angular frequency becomes dependent on the chosen inertial reference frame. The center of rotation's inclusion in the reference frame is crucial for determining this independence. Understanding these distinctions is essential for accurate calculations in physics.
tade
In classical mechanics, is the angular frequency of a rotating object, planetary system etc. the same as viewed from any inertial reference frame?
All reference frames can agree on a common clock, and all frames have a meaningful way to assign a direction to the object.
They have to agree on the center of rotation, but that should be easy for rotating solid objects, planetary systems and so on.
The key to the answer is whether the centre of rotation is part of your reference frame. If two objects circle each other around their common centre of mass the angular frequency of this rotation is independent of the inertial reference frame. If, on the other hand, you consider rotations around the origin of your coordinate system (something that is usually done in conservation of angular momentum calculations) then the instantaneous angular frequency will depend on the inertial reference frame.
I understand. thanks
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
35K
