Is a conventional lathe a 1.5 axis machine tool?
  • Thread starter Thread starter Mohankpvk
    Axis Machine
A conventional lathe is typically considered a "1.5 axis" machine because it has two axes of motion (X and Z), but only one can be effectively used at a time during operation. The X axis controls diameter, while the Z axis is parallel to the spindle. CNC lathes, which can coordinate movements on both X and Y axes, are classified as true 2-axis machines. The discussion also touches on the classification of milling machines with multiple axes, where separate actuators for tool and table movements are counted as distinct axes despite producing similar relative motion. Overall, the terminology around machine axes can vary, but the functional distinctions remain important in machining contexts.
Mohankpvk
In a lathe, the cutting tool can be moved in the horizontal plane(x and y axes).So x and y are the 2 axes.
But one of my teachers said that lathe is a 1.5 axis machine.Is it right?
Why are conventional drilling press,shaper and planer half axis machine tools?
it is good for you to ask questions. it is how we learn.
From a very good machine tool publication-
https://www.practicalmachinist.com/vb/cnc-machining/definition-each-lathe-axis-152203/
On a lathe it is standard for the Longitudinal to be Z and the Radial to be X. Vectors are I and K
The axis parallel to the spindle axis is always Z, whether its a mill or lathe. And, for the lathe, the axis that controls the diameter is always X.
And the Lathe rotary axis conform to the standard of A rotates around X, B around Y, and C around the Z.
C is the most common on a Lathe, as it relatively easy to turn the chuck into a C axis.
your teacher may be referring to the length of the lathe travel. I have sold coordinate measurement machines and these are typically described in length of travel. so see if the lathe can traverse 1.5 meters or 60 inches.
Ask your teacher what is needed to make a lathe a 2 axis machine.
Or ask the teacher to name a 2 axis machine.
a manual lathe is a '1.5 axis' machine, in machinist parlance. It has 2 axes of motion, but only 1 can be (usefully) operated at a time. A lathe with CNC on X and Y can coordinate motion, and is a 2-axis machine.
Likes joshmdmd, Asymptotic, Mohankpvk and 2 others
Nice answer.I have another doubt.
In case of mills with more than 6 axes,the tool movement along x and the table movement along x (both have separate actuators) are counted as two different axes.But both these movements produce the same relative motion between the tool and the workpiece.Why are they considered different?
Please suggest a good book to learn about these.
Nice answer.
Technically its a 4 axis machine, since the tool can be moved in/out up/down (although rare on newer models) and left/right and the piece can be rotated at different speeds. At least this is how it would be determined in robotics. But what you or your teacher call it is academic, it is what it is whether we call its a 1.5 axis machine or a 4000 axis machine.
rotating about the x y z axes make up the 4th 5th and 6th axis. it has nothing to do with the tool moving and the table moving.
