Is enthelpy change during isothermal process zero?
Enthalpy change during an isothermal process is not zero, as enthalpy depends on factors beyond temperature, including pressure and state of aggregation. While the internal energy change (dU) is zero for an ideal gas in an isothermal process, the enthalpy change (dH) can still be significant due to pressure-volume work. During phase transformations like vaporization or fusion, temperature remains constant, but enthalpy changes reflect the energy required to overcome intermolecular forces. Therefore, enthalpy values such as enthalpy of vaporization and fusion remain relevant despite constant temperature conditions. Understanding these concepts is crucial for analyzing thermodynamic processes.
RUSI16
is enthalpy change during isothermal process zero? if it is zero then what is the significance of enthalpies like enthalpy of vapourization or fussion since during phase transformation temperature remains constant.
Science news on Phys.org
H = U +PV so dH =dU + PdV + VdP. For an ideal gas, dU =0 for an isothermal process, so dH = PdV +VdP.
For melting ice which occurs at constant T, there may be negligible change in P and V, but is ΔU =0?
AM
You answered your own question. Enthalpy is not just a function of temperature. It is also a function of pressure, state of aggregation, and chemical composition.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
