Is f constant if limf(z) exists and is nonzero as z tends to z0?
AcC
Let f:C\rightarrowC be differentiable, with f(z)\neq0 for all z in C. Suppose limf(z) is exist and nonzero as z tends to z0. Prove that f is constant.
Are you stating the problem correctly? The complex exponential e^z satisfies all of those conditions but is obviously not constant.
Yes you are true!?? but I found this question in complex analysis book, I tried to solve but I hadnt thought that it could be false..!
Take limit e^z as z→-infinity it equal to zero, so it not satisfy the statement. I proved this statement with using Liouville Theorem.
In my books it's written that any integral over a closed loop \gamma equals zero:
\oint f(z)dz = 0
But at the same time it says
\oint \frac{dz}{z-a} = i 2 \Pi I
where I is an index number saying how many times loop \gamma goes around point a.
Aren't they contradicting each other?
PS: what can I do to stop Latex going to new line every time I use it?
Uncle John, welcome to Physicsforums! Please open a new thread for your question.
AcC, in that case you should state that C includes the point at infinity, which most authors denote as C* or something similar, i.e. the extended complex plane.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
