Is <f,g> an Inner Product on C[a,b]?
  • Thread starter Thread starter Shaunzio
    Sets
Shaunzio
show that if we define the following operation:
let f=f(x) and g=g(x) be two functions in C[a,b] and define <f,g>=int(a to b) f(x)g(x)dx
show that the conditions of therom are satisified with this operation. Use h=h(x) to help with part b
this shows that this operation is an inner product
therom
a. u dot v = v dot u
b. (u+v) dot w = u dot w + v dot w
c. (cu) dot v = c(u dot v) = u dot (cv)
d. u dot u >= 0, and u dot u = 0 if and only if u = 0
I really have no idea where to begin here...
I assume you are trying to prove that your structure is an inner product. For reference, <f,g> is just a generalized way of writing a dot product (as a dot product is just one specific inner product). So what you need to prove is:
a. <f,g> = <g,f>
b. <f+g,h> = <f,h> + <g,h>
c. <cf,g> = c<f,g> = <f,cg> where c is a scalar, not a function
and so on. Plug and chug, almost.
Hi sorry. I'm still pretty confused. Is there anyway you could elaborate?
therom
It's rather confusing for us to use "<f, g>" above and "u dot v" below!
So you want to prove that
&lt;f, g&gt;= \int_a^b f(x)g(x)dx= \int_a^b g(x)f(x)dx= &lt;g, f&gt;
&lt;f+ g, h&gt;= \int_a^b (f(x)+ g(x))h(x) dx= \int_a^b f(x)h(x) dx+ \int_a^b g(x)h(x) dx= &lt;f, h&gt;+ &lt;g, h&gt;
&lt;cf, g&gt;= \int_a^b (cf(x))g(x)dx= c\int_a^b f(x)g(x)dx= \int_a^b f(x)(cg(x))dx
&lt;f, f&gt;= \int_a^b f^2(x)dx\ge 0
and
&lt;f, f&gt;= \int_a^b f^2(x)dx= 0
if and only if f(x)= 0 for all x between a and b.
Did you not consider writing out what you want to prove in terms of the given definition?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
