- #36
maria_phys
- 15
- 2
Lunct said:Is that like gravitational waves?
No gravitational waves are something else.
maria_phys said:other forces may be occur in such events. If you drop an object inside the black hole it will feel the huge tidal forces from the black hole
maria_phys said:The effect of the tidal forces wouldn't be the same like the system Earth moon. I will stressed out or shrink in one direction.
maria_phys said:A force has a direction.
maria_phys said:Newtonian dynamics works really good for objects with low masses.
maria_phys said:Take for example the gravitational force between Earth and Moon. The space-time curvature is so negligible that has no meaning.
they are due to the non-gravitational forces between the object's parts (electromagnetic forces between the atoms) that are resisting the effects of tidal gravity.
maria_phys said:Newtonian dynamics works really good for objects with low masses. Take for example the gravitational force between Earth and Moon. The space-time curvature is so negligible that has no meaning.
maria_phys said:the only forces in GR are those between atoms (electromagnetism, weak and strong force)?
maria_phys said:Can the strong tidal forces from a black hole change the structure of an atom?
No, not exactly. I did not say this. In Newtonian gravity, gravity is a force. In GR it is an effect of curved spacetime. Whether the masses are small or not does not matter.maria_phys said:Exactly. We assume that gravity is a force for systems with low masses (like our Earth and moon) .
This is not true, it keeps the Moon orbiting the Earth.maria_phys said:The space-time curvature is so negligible that has no meaning.
GR is applicable in all situations where Newtonian gravitation is applicable and then some. It works perfectly well for weak fields.maria_phys said:But I've tried to clarify when GR has a meaning.
PeterDonis said:Tidal gravity is not a force in GR, as I said before. Strong enough tidal gravity could in principle break atoms apart, yes--because the force between the electrons and the nucleus is not strong enough to hold the atom together against the effects of sufficiently strong tidal gravity (meaning, the effects of sufficiently strong spacetime curvature).
maria_phys said:Could the strong tidal gravity overcome the strong force between the quarks?
PeterDonis said:When the tidal gravity is strong enough, yes.
maria_phys said:assuming that quarks are moving freely in an environment with very strong tidal forces and gravity, can the shape (and properties) of them be changed?
PeterDonis said:I'm not sure what you mean by the "shape" of a quark, or "properties". Tidal gravity can't change things like the quark's mass or color charge.
maria_phys said:A particle could be transform into a string, inside a back hole because of the huge tidal forces?
PeterDonis said:What do you mean by a "string"?
maria_phys said:if the tidal force can stressed out the quark, transform it into a string..
maria_phys said:Having a quark moving freely inside the black hole, could tidal forces stretch it out?
maria_phys said:I'm talking about the case of quarks consists of strings.
PeterDonis said:Do you mean strings as in string theory?
Buzz Bloom said:I experience gravitational "force" with an additional different meaning than what has been discussed here so far. I directly feel an upward force on the bottom of my feet when I stand on a floor.
Hi pervect:pervect said:You can feel that same "force" on your feet in an accelerating elevator (usually called Einstein's elevator) as well as by gravity.
Hi Mister T:Mister T said:If the floor (and you) are in free fall the gravitational interaction between you and planet Earth is still present, but you can't feel or measure it locally, by for example, standing on a bathroom scale.
Buzz Bloom said:I experience the force when I am stationary with respect to the gravitating source due to something preventing me from accelerating, like the floor.
Hi gnnmartin:gnnmartin said:The tidal ‘forces’ do not make a body deviate from a timelike geodesic, so they are not truly forces: again, again, to describe them as forces is to use metaphor.
Hi Arkalius:Arkalius said:The floor isn't "preventing" you from accelerating. It's accelerating you upwards, away from the spacetime geodesic that gravity would have you move along otherwise.
Buzz Bloom said:Hi pervect:
The point I was hinting at was that there is a perception of a gravitational force on your feet which is directly experiential in the real world in which we live. It does not depend on which model we use to understand the properties of this "force". In that sense, there is an undeniable gravitational "force" in the real world.
Hi pervect:pervect said:Would you agree with point 2, above, or not?
Hi Peter:PeterDonis said:The force you experience in this case is not gravity.
Buzz Bloom said:What I seem to be unable to explain clearly is that what is experienced by my feet is the same whether the elevator is on the ground or being accelerated in empty space.
What bothers me is not the use of language in discussing the physics. It is what seems to me to be a dogma that this is the only correct way to use the language and fails to recognize that there is a different natural use of language which is to be discouraged.
Hi Mister T:Mister T said:The floor exerts a force on your feet that is electromagnetic.
