I Is it possible for the Moon & a pair of planets to conjunct as smiley face?
  • I
  • Thread starter Thread starter swampwiz
    Moon Pair Planets
The discussion explores the feasibility of the Moon and two planets forming a smiley face in the sky. It highlights that for this to occur, the Moon must be positioned between the planets and the Sun, but the planets are typically close to the Ecliptic, making this alignment challenging. Observations from various astronomical resources indicate that the planets and the Moon are not in proximity on the proposed date, suggesting the event may be exaggerated or a hoax. The Moon's size and its movement relative to the planets further complicate the possibility of achieving a recognizable smiley face. Ultimately, the consensus leans towards the event being unlikely or misrepresented.
swampwiz
I was reading this:
http://www.physics-astronomy.com/2020/04/set-your-alarm-jupiter-venus-and-moon.html
It seems that for this to happen the Moon would need to be in-between the pair of planets and the Sun - but the Sun's path defines the Ecliptic, and the bright planets are all very close to the Ecliptic, certainly closer than the size of the Moon.
Astronomy news on Phys.org
No reason why it's not possible.
Moon is only 1/4 degree wide.
After checking a couple of resources (Celestia, World Wide Telescope, and Horizons web site), I've come to the conclusion that this supposed meeting up isn't going to happen. On that day, none of these bodies are even in the same part of the sky according to any of them. The Moon isn't even that much of a crescent. Now on May 16, 2010, the Moon was a thin crescent, and Venus was also in the right part of the sky, (both in Taurus) but no Jupiter(It was in Pisces). I think this might be another of those "Mars will appear as large as the Moon" things.
Hmmm...
Given the 'classic" smiley face..
It appears impossible because the planets would be behind the moon.
If you instead want to say, "Yeahbut I'm looking for an approximate smiley face, I think you need to tell us how close is close enough.
How about close enough to entice astro-virgins off the couch to go out and gaze at the Heavens, possibly inspiring new hobbyists?
Likes jrmichler
Assume a spherical smiley face...there is a joke here somewhere but I seem to have lost it.
It is just the right time of year here...no bugs and maybe a sweatshirt...
DaveC426913 said:
Fourmilab's virtual telescope suggests Jupiter and Venus are nearby, though a pretty lopsided smiley.
http://www.fourmilab.ch/cgi-bin/Yourtel
Interesting. World Wide Telescope shows this for the relative positions of Jupiter and Venus for this date
( arrows are sight-line from earth).
Celestia shows this Looking over the Earth towards the Moon, neither Jupiter or Venus are shown close, though Neptune is in the picture.
You have to rotate the view quite a bit to see Venus, and by then the Moon is well off to the side of its orbit in relation (white dot on right side of red ellipse over by Mercury in the image).
Going by the Dec and RA given by the Horizons site, these are the positions of the three on that date:
While the Moon and Jupiter look close in this image, it is a 360 degree wrap- around, and they are over 45 degree apart in the sky. Venus is over 90 degrees away from the Moon (which agrees with Celestia)
I wonder why the discrepancy from what you found?
Dunno. But I'd trust a virtual telescope with a view of the sky from Earth over - er - spitballing it from a sim of the Solar System, but YMMV.
[EDIT]
I've changed my mind.
'In the sky' seems to be giving me similar results to yours.
https://in-the-sky.org/whatsup.php?year=2020&month=4&day=18&town=6167865
I'm wondering if this is a hoax - that it occurred on that date in some other year and they've just updated the year.
But the planets would need to be that much off of the Ecliptic so that the Sun would be on the other side of the Moon from the planets.
EDIT: OK, it looks like Venus & Jupiter are 3.4 & 1.3 degrees off the Ecliptic plane, so the Moon could just barely nudge itself in between, but it would still be "daytime" dawn/dusk so the planets would not be visible, and the terminator on the Moon would almost completely encompass the whole disk.
A minor point, but to be accurate the moon is 1/2 a degree wide.
Likes swampwiz
On may 16, 2010, this is what you would have seen from Perth, Australia (Sun below horizon).
And on Dec 1, 2008, you could have seen this:
Not exactly the image being promoted, But I think we can be pretty sure that this recent one is a hoax.
Likes swampwiz
I hadn't thought of a pair of planets being at the same "hour angle" along the Ecliptic (whatever that is called) with the separation due to the angle of their respective orbital plane with respect to the Ecliptic. With that as a possibility, it's no problem for the Moon to be the proper smiley position. I could see a very good popping up every once in a long while!
Dang it! I knew that, and overrode my first answer. (Google said radius is .26. Oops.)
Likes Klystron
On the night of 1 December 2008, there was a frown. Below is a screen shot for this event from the Stellarium app on my laptop.
Vanadium 50 said:
Hmmm...
Is it possible for a Moon and two planet smiley face to wink as Moon occults two planets simultaneously and then both planets emerge from dark side of Moon, not quite simultaneously?
It depends on where in the world you viewed it from. The Moon moves at about 1/2 degree per hour relative to the stars. Thus the time of day you are viewing it on that particular day will determine its relative position with respect to Jupiter and Venus. Where you are in the world will determine what you would see while the Moon is above the horizon and the Sun below it. So in Argentina on that date sometime after sunset, you would see something like your image. However, just after sunset in western Australia, You would see that arrangement shown in my image. This is because of the time difference between sunset in Argentina and in Australia and how much the Moon moves relative to Jupiter and Venus in the intervening hrs.
