Is it possible to get an explicit solution for this?
  • Thread starter Thread starter pondering
    Explicit
An explicit solution for the equation x = 10log(x) + 30 can be derived using the Lambert W function. The discussion highlights that while an implicit solution is evident, numerical approximations suggest that real solutions are around 0.0001 and 46.6925. The transformation of the logarithmic equation into a form suitable for the Lambert W function involves converting logs to base e and rearranging the equation. Users are encouraged to improve their guesses systematically to find numerical answers. Ultimately, the Lambert W function is essential for obtaining an explicit solution to this logarithmic equation.
pondering
x = 10logx + 30 (log is log base 10)
I cannot get to anything other than this implicit solution. By trial and error I can tell that x must be slightly more than 1/1000 but I would like to get an exact answer.
Mathematics news on Phys.org
You need a function such as the Lambert W function to get an explicit solution. Real solution are approximately .0001 and 46.6925.
Thanks for the reply. I know you probably don't want to give me the answer right out but in looking at that Wikipedia article I still don't see how to do it. I am not able to get both x's on the same side in any manner resembling the examples from the article.
It can be a little tricky. These log's are base e.
x = (10/log(10))log(x) + 30
(-log(10)/10)x=-log(x)+30(-log(10)/10)
(-log(10)/10)x+log(x)=log(10^-3)
(-log(10)/10)x+log((-log(10)/10)x)-log(-log(10)/10)=log(10^-3)
(-log(10)/10)x+log((-log(10)/10)x)=log(-log(10)/10^4)
(-log(10)/10)x=W(-log(10)/10^4)
x=(-10/log(10))W(-log(10)/10^4)
There are log's of negative numbers in there.For finding numerical answers, you can improve your guess systematically
guess 50
x = 10log10(x) + 30
guess 0
x=10^(x/10-3)
Then in each case put the guess into the right hand side over and over until it changes very little.
ie
50
10log10(50) + 30~46.9897000
10log10(46.9897000) + 30~46.7200267
~46.6950
and so forth
First convert your log to base "e", and then write your equation in the form,
\ln(x) = ax + b
Now exponentiate both sided and put it in the form,
x = e^b \, e^{ax}
Finally mult both sides by (-a) and rearrange into the form,
(-ax) e^{-ax} = k
It should then be straightforward to use the Lambert W function.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
