Is it possible to get an explicit solution for this?
  • Level: Undergrad
  • Thread starter Thread starter pondering
    Explicit
4 replies · 3K views · last reply
pondering
x = 10logx + 30 (log is log base 10)
I cannot get to anything other than this implicit solution. By trial and error I can tell that x must be slightly more than 1/1000 but I would like to get an exact answer.
Thanks for the reply. I know you probably don't want to give me the answer right out but in looking at that Wikipedia article I still don't see how to do it. I am not able to get both x's on the same side in any manner resembling the examples from the article.
It can be a little tricky. These log's are base e.
x = (10/log(10))log(x) + 30
(-log(10)/10)x=-log(x)+30(-log(10)/10)
(-log(10)/10)x+log(x)=log(10^-3)
(-log(10)/10)x+log((-log(10)/10)x)-log(-log(10)/10)=log(10^-3)
(-log(10)/10)x+log((-log(10)/10)x)=log(-log(10)/10^4)
(-log(10)/10)x=W(-log(10)/10^4)
x=(-10/log(10))W(-log(10)/10^4)
There are log's of negative numbers in there.For finding numerical answers, you can improve your guess systematically
guess 50
x = 10log10(x) + 30
guess 0
x=10^(x/10-3)
Then in each case put the guess into the right hand side over and over until it changes very little.
ie
50
10log10(50) + 30~46.9897000
10log10(46.9897000) + 30~46.7200267
~46.6950
and so forth
First convert your log to base "e", and then write your equation in the form,
[tex]\ln(x) = ax + b[/tex]
Now exponentiate both sided and put it in the form,
[tex]x = e^b \, e^{ax}[/tex]
Finally mult both sides by (-a) and rearrange into the form,
[tex](-ax) e^{-ax} = k[/tex]
It should then be straightforward to use the Lambert W function.
