Is it possible to see objects at 600m distance in infrared
  • Thread starter Thread starter Calconceptofnumber1
    Infrared Light
Seeing objects at a distance of 600 meters using a 500-lumen torch with an infrared filter and goggles is complex. The effectiveness depends on whether the torch emits infrared light, as standard flashlights may not produce any IR output, potentially rendering the filter ineffective. Visibility can be improved by using the torch in mist or fog, which helps to visualize the beam. The type of infrared technology used, whether thermal or near-visible, also significantly impacts performance and range. Ultimately, the specifications of both the goggles and the light source are crucial for determining visibility at that distance.
Calconceptofnumber1
Hi I am wondering if it is possible to see the full distance of a 600m beam from a 500lm torch with an infrared filter and infrared goggles?
Science news on Phys.org
Do you really want to look at the beam - or an object at the end of the beam that is illuminated?
To look at the beam, you would have to project it into a mist (perhaps up into a cloud).
As long as you are not looking through fog, there should be no problem.
Of course, it will depend on the goggles and on the reflectivity of the scene.
I would review the specs on the goggles.
I have used a thermal IR scope that was capable of identifying a swimmer at 2 clicks.
That's not the same as your situation for a couple reasons:
1) Thermal IR does not require illumination.
2) The device was considerably larger than goggles (roughly an 18cm aperture).
3) It had a price tag well over $200K - likely not what you are considering.
I have also used a portable IR scope - but for distances out to only roughly 150m.
That one had a price tag of about $120.
Also, it matters if you are talking about thermal or near visible infrared, (illuminated or self illuminating).
On taking a second look at your question, there is a problem. I was originally assuming that your 500 lumen torch was an IR torch - and that you were looking at it through a IR filter.
If it is a normal torch (aka "flashlight"), it may not put out any IR at all. So the IR filter could come pretty close to blacking the flashlight out all together.
IR will not travel through glass. So the light bulb will block a lot of the IR. If the flashlight uses a glass pane, that will block almost all of what's left.
Likes russ_watters
This is a confusing question: if your light output is specified with 'lumens', you have no information about the radiated power outside of the visible spectrum- there could be none, or there could be a lot. Then there's the issue about 'infrared filter/goggles': what is the passband of the filter, what is the detection band of the goggles?
Likes davenn and russ_watters
Hello ! As we know by definition that: "Constructive interference occurs when the phase difference between the waves is an even multiple of π (180°), whereas destructive interference occurs when the difference is an odd multiple of π." But my question is in the case of destructive interference, what happens to the energy carried by the two electromagnetic waves that annihilate, the energy carried by the electromagnetic waves also disappears, or is transformed into some other type of...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
