Is it possible to step up DC voltage to 300V from only 4V?
  • Thread starter Thread starter junguo93
    Dc Voltage
The discussion revolves around the feasibility of stepping up a DC voltage from 4V to 300V. Participants explore methods for achieving this voltage increase, including the potential use of inverters and inductors, while considering the limitations of the source voltage from a photovoltaic cell.
  • Exploratory, Technical explanation, Debate/contested
  • One participant inquires about the possibility of stepping up DC voltage using inverters and whether this is the only method available.
  • Another participant suggests that to produce a higher DC voltage, it is necessary to vary the current, which can induce a higher voltage using an inductor, and mentions that this can be done without a transformer.
  • A follow-up question addresses the challenge of varying current when the 4V is produced by a photovoltaic cell, which may have limitations in current output.
  • It is noted that stepping up the voltage significantly would require a proportionate increase in current from the low voltage source, emphasizing the relationship between voltage and current (VA = voltage × current).
Participants express differing views on the methods available for stepping up the voltage, and the discussion remains unresolved regarding the best approach and the limitations of the photovoltaic cell.
Participants highlight the dependence on the characteristics of the photovoltaic cell, including its current output capabilities, which may affect the feasibility of stepping up the voltage.
junguo93
I only learned of AC-AC stepping up, i am just wondering if there is a possibility for a DC-DC Stepping up, for about a 4V to a 300V. If it is possible please help me out with this..
I was wondering if it is about converting DC-AC stepping up AC-DC, though the use of inverters. I am also wondering if it is the only way.
One way or another, if you want to produce a higher DC voltage than the DC one you've got already, you have to vary current in some way so that you can then induce a higher voltage, using an inductor of some kind.
This can be achieved without explicitly using a transformer (an appropriate circuit with just an inductor can work) and it is often achieved using much higher frequencies than the Mains. There are hundreds of alternative circuit designs but they all have the common basic features of an oscillator and an inductor.
Thanks for the Reply, but how do we vary the current, since i am actually producing the 4V with a Photovoltaic Cell, which i do not think is capable of a good range of currents?
Obviously, if you step up the voltage by nearly 100 times, you will end up needing 100 times the current from your low voltage cell. VA is the name of the game.
  • · Replies 31 ·
  • · Replies 26 ·
  • · Replies 39 ·
