Is Mass Relative? - Exploring the Question
In summary, the conversation discusses the concept of mass and its relation to energy in the context of the General Theory of Relativity. It is mentioned that according to Leonard Susskind's Black Hole War, as an object gets closer to the center of a black hole, it loses potential energy which is then radiated as heat, causing a loss in mass. The conversation also questions the meaning of mass and its relativity, and whether there is a mass that stays invariant in all reference frames. There is a debate over the use of the terms "relativistic mass" and "invariant mass" in modern physics and how it can lead to inconsistencies in discussions. The conversation ends with a suggestion to refer to physics textbooks for a clearer understanding
derek.basler
67
Ok this may or may not sound like a very stupid idea. But having read the Black Hole War by Leonard Susskind, he makes a claim that as the Earth gets closer and closer to the center, squeezed by gravity, it loses potential energy. The lost potential energy is then radiated as heat, and therefore the Earth loses energy. And since energy and mass are inter-related, the Earth thereby loses mass. However, if my understanding is correct, potential energy is a relative measure [ P.E = mgh]. So would that also make mass a relative aspect as well, since energy is really mass? My understanding of the General Theory of Relativity is somewhat weak, so if anyone could just clear this up I would greatly appreciate it.
Of course it is. That's true in the special theory as well: if the mass of an object is m0 in a coordinate system in which it is at rest, its mass as measured in a coordinate system moving at speed v with respect to it is
[tex]\frac{m_0}{\sqrt{1- \frac{v^2}{c^2}}}[/tex]
So mass is not a set number at all then. If you were traveling next to an object at the same velocity, and you measured its mass, and then some how measured it while you were at rest and the object was still moving, their masses would differ?
Sounds weird. I was always told I'd _lose_ weight by jogging. :)
You got it!
Mass, length, time, kinetic energy are all relative.
Electric charge and potential energy seem fixed. And I still wonder about potential energy.
I wonder what physics mean by MASS by default?
Relativistic (like in this thread) or Invariant mass?
I was told in this forum that in modern physics mass=invariant mass as relativistic mass is just a synonym for E/c^2 and is useless.
The mass needs to be useful. One useful application should be for gravitational force calculation.
well it seems that you change in mass would be equal to your change in energy, potential or kinetic, then that divided by the speed of light squared plus your rest mass? Is there a mass that stays invariant no matter what reference frame you observe it from?
Yes, the invariant mass [itex]m_0[/itex] which can be calculated from
[tex]m_0 c^2 = \sqrt {E^2 - (pc)^2}[/tex]
has the same value in all inertial reference frames.
The relativistic mass (aka total energy) is relative. The invariant mass (aka rest mass) is invariant. Typically the unqualified term "mass" refers to "invariant mass".
That does seem to be a convention favored by some here, yet in books I read by Smolin, Hawking, Penrose, Greene, Randall and others, they seem to routinely use relativistic mass...I don't see it as a big deal either way...
True. The Earth loses invariant mass during this process. It's a pity that pervect is no longer around to give a short lecture on the meaning of "mass" in GR.
The big deal is that people get replies without specifying the meaning of the "mass".
The same person can get inconsistent replies in parralel threads, like "is mass conserved? yes", "is mass invariant? yes"
Are they textbooks of physics currently used at university? Because if they were, it would be serious; if they are not, then I suggest you to look up in physics textbooks.
1. Is mass relative?
Yes, mass is relative according to Einstein's theory of relativity. This means that the mass of an object can change depending on its velocity and the observer's frame of reference.
2. What is the difference between mass and weight?
Mass is a measure of an object's inertia or resistance to changes in its motion, while weight is a measure of the force of gravity acting on an object. Mass remains constant regardless of location, while weight can change depending on the strength of gravity.
3. How is mass measured?
Mass is typically measured using a balance or scale, which compares the unknown mass to a known mass. In scientific research, mass can also be measured using instruments such as mass spectrometers.
4. Can mass be created or destroyed?
According to the law of conservation of mass, mass cannot be created or destroyed. It can only be transformed into other forms of energy through processes such as nuclear reactions.
5. How does mass affect an object's motion?
Mass is a key factor in determining an object's motion. Objects with more mass require more force to move and accelerate, while objects with less mass require less force. This is described by Newton's second law of motion, F=ma.
